Geronimo John started following Awning replacement , North Rim Closed for 2025 , A different refrigerator fan option and 3 others
Agree totally. For those not familiar, here is a site with pictures of the lodge and area: https://www.grandcanyonnorth.com/gallery So sad. GJ
Our Experience with the Starlink Mini is the same as Ronbrink. We traveled for many years with an ATT NetGear portable cellular hub but have repalced the NetGear with Starlink. We spend a good part of time off the grid and Starlink provides service everywhere except when you have abstructions such as trees between you and the satellite. The ATT NetGear is great device, it's portable, simple and easy to use. If we didn't spend time off the grid, we would likely stay with the ATT NetGear hub. With an ATT business account our NetGear plan was $65 monthly (+ buying it over time as with cell phones) with unlimited data use.
Changing tires in the wild - lessons learned
Geronimo John replied to John and Jodi's topic in General Discussion
Once I had to get out a drill and make a hole so I could get the plut into the leak. Wasted an hour trying to do so before the light bulb came on. I also have had leaks in the main tread area that took three plugs to slow them down. Even with three, it still leaked, but slow enough that I could get off the mountain by re-airing up twice. Good idea to have an air compressor of some sort! GJ - Today
Starlink Mini Installation- 2022 LEII- Alternate Approach
Steve and Cindy replied to dhaig's topic in Ollie Modifications
@dhaigI like your setup and I'm going to give it a try. With the RJ45 pass-thru connector, do you have to take any precautions in rainy weather with water getting into that connection from outside the trailer and causing problems? -
I hate to admit it now - but - I was one of those that thought I could not live without a dry bath. During fairly early discussions with Anita (Oliver Sales) I told her of my concern in this regard. Without missing a beat, she explained to me the relative value of the real estate (i.e. square footage) of the dry bath versus the wet bath. Indeed, Oliver could convert the closet into a dry bath, but what is the value of that closet versus the relatively small amount of time that one actually spends in the bath every day, she said. Having an undergraduate degree in economics this spoke straight to my understanding of the "economics" of the situation and the rest is history. And, as with most things, Anita was right - at least for me. Bill
I may remember a post about an interesting retirement job🤔 Mossey
When ‘inquiring minds want to know’, ask AI! My question: Will the Starlink Mini support use of two laptops streaming TV content? AI response: Yes, the Starlink Mini can support two laptops streaming TV content simultaneously, and often even more devices. The built-in Wi-Fi router is designed to handle up to 128 devices, and real-world tests show it works well for multiple streaming sessions. The main factor influencing performance will be the available bandwidth at your specific location and time of use, as speeds can vary. Performance and Considerations Speed: The Starlink Mini typically delivers download speeds over 100 Mbps, and users have reported speeds over 200 Mbps in optimal conditions. This is more than enough bandwidth for two simultaneous high-definition streams. Reliability: While generally reliable, speeds may temporarily decrease during peak network times or due to minor obstructions, which could cause a brief glitch in a stream. However, in most scenarios, users report no issues with multiple concurrent streams. Data Usage: Be mindful of your data plan. The Roam 50GB plan has a data cap, and streaming TV content consumes a significant amount of data. The Unlimited plan may be more suitable for frequent, heavy streaming use. Built-in Router: The Mini has an integrated Wi-Fi 5 router, which is sufficient for a campsite or small area. If you plan to be further away or want maximum performance, some users suggest adding an external hardwired router.
We loved our Casita but I could never go back to the rat fur on the walls. Looking at the layout of the Casita 24 made me wonder if I would trade the closet in the Oliver for the dry bath layout in the new Casita. For me it's an easy no. But I often hear the wet bath in the Oliver is a non starter for some folks.
Brilliant!
Geronimo John replied to Snackchaser's topic in Ollie Modifications
I hate mubdobbers and wasps! This idea is a good one for that size bug. Inexpensive too! We run our fans 20/7 for months at a time. I have two new fans to replace my smaller ones. I'm thinking blocking off most of the top vent with 1/8" thick white plastic, and making two fan size holes to allow the fans to discharge directly outside. No screen needed there for this approach. This would eliminate the circulation effect that occurrs in a more open design where air can come out of the fan and circulate back into the fan's suction side. Sort of a "Ducted Fan" approach. Below I like the idea of using this screen all across the bottom vent area and using an inexpensive home A/C filter as a bug stop to the outside of the screen. The above vent being powered and sort of ducted will likely improve air flow actually out of the refer box area. That would over come the static resistance of the screen and filter below. Combined nearly all bug proof, not just my two worst friends mentioned above but smaller ones as well and areduce someof the dust that gets sucked into the refer backside. PS: I keep a fresh can of Wasp Spray in my front storage box for "encounters" of the worst kind. GJ -
SDG air conditioner installation
Geronimo John replied to mountainoliver's topic in Ollie Modifications
From a M.E. perspective the smaller unit was intended to run longer than the 13.5 units thereby better controlling humidity and pulling less power. A good thing. But it gives up high temperature condition performace (ability to reach set point) and cool down time as trade offs... as you well know. Pretty much of that logic line goes out the window with the advent of the Inverter units. They can cycle output down/up as needed for all applications under those for which they are not undersized. They control both humidity and temperature to set point. Brilliant! I suspect that OTT will be going that direction once there is a bit more experience with them and the reliability issues, good and bad, shake out. That's part of their good conservative approact to significant changes I think. As the inverter refergerator topic continues to matue, I'll be looking at the owner opinions in a couple more seasons as my Dometic 3-way ages and my confidence in the air separation from the cabin and the refer side deteriorates. Likewise with the inverter A/C units. Wish the Houghton was an inverter, but it's not. Lucky that I and others were able to do the two Mods. So I'll likely hold off an A/C upgrade to let this topic mature. Especially if the Ceilo would work well on it! I appreciate all the Owner inputs about the Cielo system and their experiences using it. GJ -
For those with an older technology (Not Inverter) I seem to have understood that the Cielo would just shut down the power to the unit in the mode when humidity "give back" from the Evaporor Coil is an issue. But with if you have more recent design (Inverter A/C), the Cielo independently controls the (Inverter (Compressor Speed), Condensor Fan, and the Supply Air Fans) to meet what ever humidity and temperature settings are needed. Is the above done by the same model of Cielo or different ones? How does it do so for both types of unit when they all likely have different mother boards? Almost sounds too good to be real. But so many of us really like what it does it must be magic! GJ - Yesterday
Casita did a pretty good job with this new trailer. Tank sizes, especially black tank, dry bath and large fridge are all good selling points. At about half the price of an Oliver this is going to provide some competition. I hope Oliver is working on their next trailer! Mike
Geronimo John replied to Treasure Coast Vault's topic in Ollie Modifications
A farm back-hoe bucket worked best for our Houghton install. Also, the Dometic if still running will generally fetches $500 to $600 on Craigs List. So don't do what one fellow did that HATED his DOMETIC P2: Tossed it over the side. Which likely is not legal due to the refergerant rules. GJ -
OR instead of getting all that hardware, you could invest a few hours and get you some of these: ; ; ; ; ; wait for it......; ; ; ; ; ; ; ; ; ; ; ; ; ; Gotcha! I was forwarned by a very wise Sea Dog (I believe) in 2018 that some day I would get older and wished I had got my Ollie with 20 # tanks. I did on both topics. GJ
We have the standard awning without wings. I like to move the picnic table half under and half outside of the awning. then I use three tie downs from the awning to the table itself. For week plus stays with tables, it beats collecting three each 3 gallon buckets of rocks for dead weights... much faster too. GJ
Thanks Mike. It is obvious I am a Mechanical Engineer. Fortunately June is a Masters Electrical Engineer and a IT Professional. So I'm the slow one in the gizmology world of these type of machines. Put power I do get!. Gathering the base level info lets me ask less stupid C.S. questions though. Many thanks for your posts! GJ
Sure! Each laptop is working independently so it only comes down to the internet "Bandwidth," which simply means how much data can be transmitted over time. Typical Starlink connections are very fast, usually greater than 100 Mega bites per second (Mbps) so you can easily stream video on more than one device at a time. That's why trailer park internet can be so slow; the more users means less available bandwidth.
The SL Mini doesn’t transmit TV, it provides internet connectivity so the user can stream whatever his device is capable of streaming. Carol and I are sometimes both on our iPads streaming different video content from the SL Mini. Mike
Alcan spring kit sprung stiffer or is it bad roads?
rideandfly replied to taylor.coyote's topic in Ollie Modifications
That's why we're taking our time replacing the springs in 2026 with Alcan springs. I don't like Dexter EZ Flex wet pin spring bushings, they were thin and fragile when installing the EZ Flex system, very easy to damage. Believe Alcan's bushings are made of more durable material and thicker than Dexter's wet pin spring bushings. This will be a good reason for us to visit Grand Junction, CO this year during our western trip. 🙂 -
Geronimo John replied to taylor.coyote's topic in Ollie Modifications
Should we not get contrary documentation, it pretty much validates the Dexter assessment that the Dexter PR4B 1750# springs are undersized for our full time loaded 6000# class trailerls. Does any OE2 oqnwe in your situtation know if the OTT installed 5200# axles on the OE2's came with the Dexter PR4 2400# springs or something different? Would be really good to know this. thanks GJ -
Bill: Lucky you to have the 5200's for free. I am going to "Assume" you are not a 5%er. If not, I get a second strike. With your super good 5200's and BEEFY brakes, and likely the Dexter 5 Leaf springs, I do not recall a single post where the 5 leaf springs on 6,000 pound class OTT's have failed. (Somebody please correct me if my memory has gone on strike in this. If so, please provide specifics.) I would continue to inspect them every season checking for flatening out of their curve. But then that would be smart for every owner to do, even those with Alcan's. 🙂 GJ -
Not aware of any 5 leaf Dexter spring failures, yet. -
katanapilot replied to taylor.coyote's topic in Ollie Modifications
Has anyone with the 5200 lb axles factory installed had a leaf spring failure?
