John Dorrer Posted November 19, 2024 Posted November 19, 2024 (edited) This has been bothering me for a while. When I connect the brake cable to the truck it hangs down to 2"-3" above the road. Can you run it up through the hitch pin with the 7-pin cord? What does everyone do? I'm concerned it is matter of time before it is hit by road debris. Having the trailer brakes activate at 60+ mph is a scary thought. Thanks, Edited November 19, 2024 by John Dorrer Typo 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
DaveAndBecky_NorthernMI Posted November 19, 2024 Posted November 19, 2024 I find if I twist mine it makes it more taut and doesn't hang so low. Same for chains. I've always worried low hanging chains and brake cable could create a spark and possibly fire in dry conditions. 3 2022 Oliver Elite II Hull#1047 "Saunter" 2014 VW Touareg TDI
Moderators Mike and Carol Posted November 19, 2024 Moderators Posted November 19, 2024 Mine is zip tied to the tongue so it doesn’t hang down. 1 5 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
rich.dev Posted November 19, 2024 Posted November 19, 2024 Get one of these John https://a.co/d/iYv5OWt 6 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
DavePhelps Posted November 20, 2024 Posted November 20, 2024 I have what rich.dev showed above and has worked great. Otherwise zip ties as Mike and Carole suggested. 56 minutes ago, DaveAndBecky_NorthernMI said: I find if I twist mine it makes it more taut and doesn't hang so low. Same for chains. I've always worried low hanging chains and brake cable could create a spark and possibly fire in dry conditions. Twisting chains to adjust length is not recommended and can dramatically reduce their strength. Best to cut them to the required length with no twist! Dave 2 4 2015 Oliver Elite, Hull 107 1998 Ford E-250, 5.4 liter
John Dorrer Posted November 20, 2024 Author Posted November 20, 2024 37 minutes ago, rich.dev said: Get one of these John https://a.co/d/iYv5OWt Nice, 👍 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
rideandfly Posted November 20, 2024 Posted November 20, 2024 1 hour ago, Mike and Carol said: Mine is zip tied to the tongue so it doesn’t hang down. Same here 4 2015 LE2 #75 / 2024 F-150/5.0L
Patriot Posted November 20, 2024 Posted November 20, 2024 I hang my cable in the Sea Biscuit “Moose Rack”. It keeps it at the right height while under way. So far so good. 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
Mountainman198 Posted November 20, 2024 Posted November 20, 2024 15 hours ago, John Dorrer said: This has been bothering me for a while. When I connect the brake cable to the truck it hangs down to 2"-3" above the road. Can you run it up through the hitch pin with the 7-pin cord? What does everyone do? I'm concerned it is matter of time before it is hit by road debris. Having the trailer brakes activate at 60+ mph is a scary thought. Thanks, I route my cable over the whale tail of the Andersen. This keeps it far from the ground 4 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
Steve Morris Posted November 20, 2024 Posted November 20, 2024 16 hours ago, rich.dev said: Get one of these John https://a.co/d/iYv5OWt That's what came on ours in March 2023. 2 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Jason Foster Posted November 21, 2024 Posted November 21, 2024 Cut them down to the correct length if they hang too much but also make sure you cross them at least once, so if the trailer hitch comes off the ball, it drops onto the chain crossing. 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Jason Foster Posted November 21, 2024 Posted November 21, 2024 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
John Dorrer Posted November 21, 2024 Author Posted November 21, 2024 2 hours ago, Jason Foster said: Cut them down to the correct length if they hang too much but also make sure you cross them at least once, so if the trailer hitch comes off the ball, it drops onto the chain crossing. My post was about the brake cable hanging too low, not the chains🙃👍 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Jason Foster Posted November 21, 2024 Posted November 21, 2024 35 minutes ago, John Dorrer said: My post was about the brake cable hanging too low, not the chains🙃👍 I plea the 5th. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
John Dorrer Posted November 21, 2024 Author Posted November 21, 2024 7 hours ago, Jason Foster said: I plea the 5th. 🤣 I did get a good chuckle. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Ronbrink Posted November 22, 2024 Posted November 22, 2024 I soon replaced the stock brake cable with the red coiled cable, like the one @rich.dev mentioned, after stepping over the trailer tonge when hitched and tripping myself; yep face forward fall, lesson learned. (It’s okay to laugh!) 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
John Dorrer Posted November 22, 2024 Author Posted November 22, 2024 3 hours ago, Ronbrink said: I soon replaced the stock brake cable with the red coiled cable, like the one @rich.dev mentioned, after stepping over the trailer tonge when hitched and tripping myself; yep face forward fall, lesson learned. (It’s okay to laugh!) Just got mine from Amazon. When I go to storage, I will swap it out and coil the old one and keep it as back-up. 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Coastal Aggie Posted November 23, 2024 Posted November 23, 2024 Lucky this came up just as I was getting around to fixing it. On my way back from alaska this year I ended up having to hit an empty DEF box in the middle of the road. Didn't have a chance to avoid it but if I had thought more about it I would've at least gone over it off center instead of just straight on (initially figured itd be better for it to hit the part of my bumper that sticks down to protect the winch/diff in the center), ended up smashing the plastic loop that holds the cable to the "pin thing". Didn't even realize it was broken until a couple days later when I went to inspect everything to make sure it was still good. 2 2018 F150 FX4 5.0v8 2022 Oliver Elite Hull #1285 2023 Oliver Elite Hull #1434
Ronbrink Posted November 23, 2024 Posted November 23, 2024 (edited) 8 hours ago, Coastal Aggie said: On my way back from alaska this year I ended up having to hit an empty DEF box in the middle of the road. Had a similar incident last trip on our way out of Houston, but a slow rolling tire was the ‘target’! Out of nowhere, said tire came rolling into my lane with little time to react and lane change not an option given the heavy traffic. Following some ‘flagrant language’, I immediately started to slow my speed to time for an impact at vehicle dead center. As I worked my way over to the first available exit, my thoughts were on potential damage to the Oliver, most likely to the fiberglass. Thankfully all was found good, but had the tire been on a rim this would have certainly been a dire situation. Edited November 23, 2024 by Ronbrink 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
