hardrock Posted August 6, 2017 Share Posted August 6, 2017 I have the standard Furrion Stereo and standard TV. Many times when I get to the campsite, my TV works, my stereo head works, but they do no "Talk" to each other. No DVD player signal. Upon close inspection, removing the stereo head, I can see the TV cable dangling, unplugged from the head. I plug it in, all is well. However, each trip in the camper, same issue, the cable unplugs too easy. Any suggestions? Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted August 6, 2017 Moderator+ Share Posted August 6, 2017 What type of cable is it. HDMI, RCA? Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted August 7, 2017 Moderators Share Posted August 7, 2017 The Furrion connects to the TV with an HDMI cable. I've never experienced a loose HDMI connection. Is there any stress or tension on the cable? Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
cptgringo Posted August 7, 2017 Share Posted August 7, 2017 Mine has disconnected three times. From the back of the tv. It's easy to reinstall but requires working upside down on the bed. Link to comment Share on other sites More sharing options...
John E Davies Posted August 7, 2017 Share Posted August 7, 2017 Mine has disconnected three times. From the back of the tv. It’s easy to reinstall but requires working upside down on the bed. You can easily secure it to adjacent cables using a couple of nylon wire ties. Once secured it should never move again, unless you want it to. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
hardrock Posted August 9, 2017 Author Share Posted August 9, 2017 Sorry for the long delay in replying. My daughter and family were using my Ollie. While they were at the campground, they too experienced the same problem. As Mike suggested, it is a HDMI cable that is coming loose. My son-in-law, (a IT manager for Boeing) expierenced the same thing while camping in my unit. He removed the head and said the HDMI connection was out and dangling at the back of the unit. He plugged it in and it worked fine. When they returned, we checked it again and the HDMI cable was out. When I bought my Ollie, I had a XM Satellite radio installed. Upon further inspection, these connections from the radio (and the satellite antenna going through the roof just overhead) may be creating the problem. Too much stuff in a small place. It appears some of the cabling may rest upon the HDMI cable. However, the HDMI cable slides out of the connection on the head VERY EASILY. Not sure how to hold the cable in place. Can you squeeze/ <b>LIGHTLY</b> crimp the cable to make a better connection? Can it be taped in? thanks Link to comment Share on other sites More sharing options...
Try2Relax Posted August 9, 2017 Share Posted August 9, 2017 I've never seen an HDMI connector that didn't fit snug, definitely sounds like that one must have been forced at some point. For just a little slack you can try the following, then it need be take your cable to it and it should now be snug in the head unit, it would surprise me if it was the head end that loosened. https://www.amazon.com/gp/aw/d/B004VFHMU6/ref=psdcmw_172544_t1_B00455RN92 Or https://www.amazon.com/gp/aw/d/B0126VP3QG/ref=pd_aw_fbt_23_img_2?ie=UTF8&psc=1&refRID=99WTRPR1J4M27G54S3E8&th=1 Randy One Life Live It Enjoyably 2017 F350 6.7L SRW CC LB 2015 Oliver Elite II Hull #69 Link to comment Share on other sites More sharing options...
hardrock Posted August 10, 2017 Author Share Posted August 10, 2017 All thank you for your kind replies. From the number of PM's and replies I have received, this seems to be a common problem, both at the TV connection and at the Stereo head. I will try some of the suggestions you have sent me. Thank you very much Hardrock Link to comment Share on other sites More sharing options...
