You know how it is when you are parked just slightly off level toward the street - the door will not stay open, no way, no how....
The eyelet is a thin piece of stainless steel, with a hole in it just large enough to allow two sections of standard nylon paracord to slide through it with a good amount of drag. When installing onto the door, be sure to support the bottom of the door or it might come apart, since that screw holds the frame together at the upper corner.
The cord is adjustable for length just by sliding it, and you can remove it entirely by pulling through the eyelet since there is no knot in the left side of it.
Set the length so that it will just slip under the knob at the bottom for travel.
Works good, if you slip the end under just the outer arm of the coat hook, you can still hang stuff like hats from it.
Be sure to sear the cut ends or they will look nasty. And you don't have to use bright green ;)
We just got the small door magnets. On Command strips hold one on the bottom of the door and one on the side under the dinette seat. They work well and not very noticeable at all. Mike
  • Thanks 4
no way, no how….
Mr. MacGyver, this one cracked me up. I appreciate your ingenuity. To my level-headed-farm-boy husband's dismay, I'm a bit of a nerd myself & was wondering ... [Keep in mind I've only been inside an Ollie II once & that was a couple months ago.] Could you slice one side of a swim noodle & cut it to fit the width of the door jam, then shove the noodle over the edge of the jam to keep the door open?
Chris & Duke Chadwell
🐾Maddie & Baxter🐾
Elite II Hull 292
Sure, a noodle or a piece of slit water pipe insulation would work for off season ventilation, but that will only hold it art way....
This is intended for when you are occupying the trailer for a short time, for example a Rest Stop, and want to keep the door fully open. Sometimes we don't disconnect and/or run down the jacks down for overnight, if I can get the trailer close to level by maneuvering. If the trailer has a slight right cant, the door won't stay open without this string, or the magnets mentioned above, which I was too dim to think of.
We keep the dog water bowl in the bathroom, so the door needs to be open most of the time.
You can always prop it open with a shoe or some other object, but that doesn't work very well.
Mike & Carol - Ya got a picture of your door magnets?
Mike & Carol – Ya got a picture of your door magnets? Bill
I don't right now. We're going to drive over to the storage in a bit to make sure all is OK. Will bring back pics.
Mike
Mike & Carol - that is very nice and CLASSY - just like both of you!
  • 10 months later...
HI Mike, I like your magnets to hold the bathroom door open. I ordered the same item. It came with holes to attach with screws but I don’t want to put holes in my Oliver. You mentioned that you attached with 3M tape. Did you use a special kind of 3M tape and is it remaining secure after using for awhile?
Nana -
I'm sure that Mike & Carol will respond, but, in the meantime -
I also used their idea and like you I didn't want to drill to install them. I used Command double sided tape:
https://www.amazon.com/Command-General-Decorative-20-Strips-GP023-20NA/dp/B0751VFF2P/ref=sr_1_5?ie=UTF8&qid=1530229593&sr=8-5&keywords=command+strips&dpID=51vrI6-Vl1L&preST=_SY300_QL70_&dpSrc=srch
of the appropriate size a year ago and there has been absolutely no movement in either magnet to date.
We used the Command double sided tape. Beside Amazon, you can find it at Walmart and Home Deport in a variety of sizes. Mike
[attachment file=Bath Door Magnet.pdf]
[attachment file=Bath Door Magnet2.JPG]
We used the magnet method also. Ours are a little flatter. Used the 3M Adhesive/sealer Oliver used on trailer. Not near trailer right now to take pics but attached is where I ordered.
Bath-Door-Magnet.pdf
Scott&Ricki
2017 Legacy Elite II Twin, Hull 225, The Bus
2007 Tundra
Prev: 2003 Casita, 2009 Weekend Warrior
OK - I will try the pic again
Scott&Ricki
2007 Tundra
Well Well Well ,
We won't pick up our Ollie until next week, and I ordered two pair from the big "A". Thanks guys, I'm ahead of the game-- for once...
Mike, just received my magnets from Amazon and installed them with Command tape. I have been looking for something just like this to replace the bungee cord that I have been using. This works great and looks much better, thanks!
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
It’s been a year since we stuck our magnets on and they show no signs of coming off! Glad it’s working for you. Mike
  • 3 weeks later...
I think this has got to be the best $5 mod that you can do!
-  Mike  Brentwood, TN  -  2018 Elite II  -  Spirit of Adventure Hull #308 -  2016 Toyota Tundra Limited 5.7L  Class IV hitch with 12k lb coupler, Dobinsons HD 2in Leaf springs, Timbren bump stops, Eibach Pro Truck Stage 2R, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
  • 5 months later...
I used Mike's magnet-and-Command-Strip method, but found that I could put one magnet on the door and the other one inside the compartment under the seat. This has two advantages as far as I can tell:
It eliminates adding another protuberance.
It weakens the magnetic pull, making it easy to pull the door back and not put any strain on the door. (These magnets are pretty powerful.) I think that someone mentioned having to put something over the magnets to weaken the pull. Putting one magnet inside the compartment accomplishes the same thing.
  • Thanks 5
Onward through the Fog!
EarthPicks of Cochise County
Jeff, brilliant! What a great idea! Why didn’t I think of that? I’m going to do as you did when I have the trailer here later this week. We’re loading up to head to Quartzsite (passing through Cochise County!) then on to California. Mike
Well, Mike, I wouldn't have thought of it if you hadn't thought of the magnet-Command-strip solution in the first place. If it works out, and you have a stay over in our neck of the woods, perhaps we can connect. It was viewing your Ollie that cinched our decision to get one.
  • 2 years later...
Spike,
did you use the same magnets that Mike & Carol used?
if not, which magnets did you buy???
My Visited North America Map
We ordered on Amazon the same magnetics that Mike and Carol have in their picture and they came with screws and double sided tape.
We put one magnetic on the bottom corner of the door and (instead of placing the other magnetic on the face of the fiberglass under the dinette seat) the second magnetic was installed inside of the cabinet, out of site, and this installation holds the door open with no problem.
