RobertH Posted September 10, 2018 Share Posted September 10, 2018 Hello all, I created a access port for the fresh water drain valve. The reason behind this is so you dont have to take your bed apart each time to gain access to the drain valve. I simple lay down on the floor and can reach the valve. This mod isnt for everyone specially those that have a issue laying the on the floor to reach it but I find it much easier to use then having to take my king bed up each time. In another post today I will show you the perfect mattress setup for the king floor plan. At least the best mattress set I have found for it so far. I purchased a Five Oceans Marine white screw in deck plate off Amazon. I went with the 5" Deck plate for 10.99 and with Prime its free shipping. The location I chose was just above the drain valve and even with the vent and I think it turned out well. I did this mode using a metal cutting blade in my jig saw. I chose the metal blade for smaller teeth. Have your wife or friend use a spray bottle on mist setting and spray it while you are cutting it with a towel on the floor it will collect all the fiberglass dust. Be smart and wear a mask anyway. Also tape the entire area. I used painters tape and over taped. This will keep the fiberglass from having issues cracking and also keep your jib from busting or scraping up the inside. There are lots of youtube videos on doing deck plates in boats. Treat it the same as those videos and things will be fine. UPDATE Oddly enough for some reason I am unable to reply to my own post. So I will answer some questions. My Hull# is 087. Its a 2015. I had 0 access to that without going through the top which ment taking apart my bed. I have made my bed a permanent or semi permanent down bed with a pair of Ghost bed mattresses. At any rate with the port I am actually able to access the fresh water drain. My Ollie has a on demand hot water heater as well so that is not as big a issue. 3 Link to comment Share on other sites More sharing options...
KarenLukens Posted September 11, 2018 Share Posted September 11, 2018 How do you add water when boondocking? Reed Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II Link to comment Share on other sites More sharing options...
mountainoliver Posted September 11, 2018 Share Posted September 11, 2018 Strange, mine came with that access port in 2017. The original one however was only 4 inches and I had the service folks change it to their standard large one. I think it is 6 inches. 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax Link to comment Share on other sites More sharing options...
Rumline Posted September 11, 2018 Share Posted September 11, 2018 Hull 344 came with the port also. I'm pretty sure it's the 6" but I never measured it. It's got plenty of room for my arm to get up in there. RobertH what year/hull# is your trailer? 2018 OLEII #344 | 2018 Ford Expedition Link to comment Share on other sites More sharing options...
bradbev Posted September 12, 2018 Share Posted September 12, 2018 The existing port (if like out 2017 model) is to reach the water heater bypass valve for winterizing. A larger port might allow you to reach both valves. Good mod! Link to comment Share on other sites More sharing options...
mountainoliver Posted September 12, 2018 Share Posted September 12, 2018 The larger port does allow me to reach both valves. Our Ollie is a 2017, hull no. 208. 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax Link to comment Share on other sites More sharing options...
Overland Posted September 13, 2018 Share Posted September 13, 2018 I asked Oliver to install the same door that they use for the basement access. Makes a big difference, but to be honest, whenever we flip the valves or drain the tank, we just flip up the mattress and use the hatch. We use the door to access the pressure tank valve, since I don't like to travel with it pressurized. [attachment file=IMG_0697 (1).jpg] Link to comment Share on other sites More sharing options...
