CedarForks Posted April 29, 2019 Share Posted April 29, 2019 This is my first attempt at de-winterizing/sanitizing. The tank was 60% full and now reads 25% but it has stopped draining. I tried opening the faucets to increase pressure but that hasn't helped. Help please! Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted April 29, 2019 Moderators Share Posted April 29, 2019 Try raising the front of your trailer. The fresh and gray tanks are very flat. Hope this helps. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted April 29, 2019 Moderators Share Posted April 29, 2019 After taking Mike's suggestion, don't worry about it (too much). All you are doing with the fresh water tank is sanitizing it. Assuming that you have done the bleach and flush routine simply take a sniff of the water that is left in the tank. If it still smells like bleach then either flush it another time or two and/or add a small amount of baking soda before you flush it that final time. Even if there is a hint of bleach odor left after flushing - it will not harm you. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
CedarForks Posted April 29, 2019 Author Share Posted April 29, 2019 That helped a lot: it's draining again. 1 Link to comment Share on other sites More sharing options...
John E Davies Posted April 29, 2019 Share Posted April 29, 2019 You can always pump the water out with the water pump. It is faster that way and won’t hurt anything. If you don’t want to fill your gray tank you can lock the outside shower handle on and let it water the roses.... The belly drain is not the fastest setup, for sure, even with the tongue raised a little. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted April 29, 2019 Moderator+ Share Posted April 29, 2019 If you're coming in from a trip with water in the fresh tank that you plan to dump when you get there, open the drain valve for the fresh water tank about thirty miles from home. It will be empty when you get there. Try to remember to close it if you don't a mess when you start to fill it next time. Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted April 29, 2019 Moderators Share Posted April 29, 2019 For the new folks, that advice might be ok in a rural area, trailing freshwater as you go, but, a cop can't tell fresh from grey or black. In an urban area, you might just get pulled over... I'll give my water to the flowerbed... https://splinternews.com/the-time-dave-matthews-band-dropped-raw-sewage-on-100-p-1793849906 http://nymag.com/intelligencer/2009/04/keith_urban_steals_tour_bus_tu.html Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted April 29, 2019 Moderator+ Share Posted April 29, 2019 For the new folks, that advice might be ok in a rural area, trailing freshwater as you go, but, a cop can’t tell fresh from grey or black. In an urban area, you might just get pulled over… Sherry For that matter, I do the gray water the same way. Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
