AndrewK Posted July 30, 2019 Share Posted July 30, 2019 I am in the process of modifying our standard floor plan to a modified twin bed floor plan (pictures to follow when complete). I ordered the twin bed rails and installed them as directed by Oliver. The bed rails were installed with nothing in between the rail and the hull and the rubber gasket, on the ledge the table sits on to make it into a bed, removed . I used eight rivets on each rail and the rails seem very secure. The problem is when you sit on the edge of the bed, there is significant gel coat to gel coat creaking. I reached out to Oliver service and Jason suggested using double sided tape between the rail and the hull. I have put a 3/4" strip on either side of the rivet holes, on the hull, and one on the vertical ledge surface. I did not remove the backing from the tape and tried a test fit. The creaking is significantly diminished but still present. Is this normal? Thank you for any insight anyone has. Andrew Andrew 2019 Legacy Elite II 2018 BMW x5 35d Link to comment Share on other sites More sharing options...
Overland Posted July 30, 2019 Share Posted July 30, 2019 It’s not normal for a factory model but this is the first I’ve heard of anyone doing a retrofit. My first thought is that the rivets might not be tight enough and maybe that’s where the creaking is coming from. 1 Link to comment Share on other sites More sharing options...
rideandfly Posted July 31, 2019 Share Posted July 31, 2019 Andrew, We had the same issue with the port side bed. Used thin gasket like material between the interior access door & interior hull over wheel well area under mattress and between the bed rail where it contacts the battery box enclosure under the pantry. Bill 1 LE2 Link to comment Share on other sites More sharing options...
