Trainman Posted August 12, 2019 Share Posted August 12, 2019 Just wondering if there is anyway to adjust our Dometic non-powered awing, the far end opposite the door is about 6" lower then the door end when extended. I see there are several screws in the arm assemblies, I know some are mounting screws, but what about those set screws I see recessed in the arm actuator, what do they do. Just wanting to know how to raise the lower end of the awing. Do many of you out there used Painters Poles on your awing, I would rather not fool with that, but if that's what is needed I might give it a shot down the lime. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Link to comment Share on other sites More sharing options...
Landrover Posted August 12, 2019 Share Posted August 12, 2019 My awning is the same way. I was told it is set that way for rain run off. Not sure about adjustment will have to take a look. Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎 Link to comment Share on other sites More sharing options...
Mainiac Posted August 12, 2019 Share Posted August 12, 2019 When you roll it up does it go into the case evenly? If so, you should be golden. Meaning fabric same length on both sides... 1 Link to comment Share on other sites More sharing options...
Mavis2 Posted August 18, 2019 Share Posted August 18, 2019 We have hull 485, and with the manual awning extended, it is pretty level side to side. We certainly do not have a six inch drop. Our first trip out, we had some light rain that pooled on the awning which was worrisome, so I kept pushing up on it to dump some water. I emailed Oliver and they mentioned the side away from the door would drop and dump water once it had enough to pour out. I really need to test this before we head out next week... Our awning rolls up even and stores tight. Sorry, I haven't tried to adjust the awning yet so can not help there, but thought it was interesting that on your Ollie one end of the awning was lower. Kim and Travis, Charlotte NC 2019 Legacy Elite II, Twin Bed 2018 LR Discovery Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted August 18, 2019 Moderators Share Posted August 18, 2019 We have an older awning. We always drop one side at least six inches, especially in a rain event. Gather and place a few small rocks/ large gravel in the rain runoff path at the low end, to keep the splashback down. If it's really windy,or lightning, we roll up the awning and move inside. Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
