Kgeb Posted January 18, 2020 Share Posted January 18, 2020 I have found my solution for the awkward plastic shower curtain supplied by Oliver when you purchase the full curtain track. I purchased a new fabric curtain, very thin and light weight. Then this is what I did: 1. Layer the new curtain flat on the floor with the plastic Oliver curtain on top. 2. Then I made allowance for finishing the edges. It must be doubled to hold the grommet. (See last photo) and cut the new curtain using the plastic curtain as my pattern plus finished edge allowance. 3. I used the existing little suction cups from the plastic curtain and attached them in the same position on the new curtain. 4. Next I placed the position of the grommets and attached them. (You can purchase a kit on line/practice first) 5. The only thing to do was check the length and shorten if necessary then hang. They are not quite perfect but they look better when not in use, they do the job and dry very quickly. 2 2 Link to comment Share on other sites More sharing options...
Overland Posted January 19, 2020 Share Posted January 19, 2020 (edited) That looks really nice. It would be nice if Oliver had a choice of material for these curtains for owners to choose from. Edited January 19, 2020 by Overland Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted January 19, 2020 Moderators Share Posted January 19, 2020 That does look like a nice solution. We are happy with no curtain but would consider this if we were curtain folks. Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Mainiac Posted January 19, 2020 Share Posted January 19, 2020 I have thought that a curtain in there was unnecessary. A cumbersome thing to hang, move, c!ean, look at, and move around. However, after looking at these picture, I may have to change my mind. With this setup, one can leave the window open while running the vent. But, maybe most important, one can keep towels in the shower area, instead of on a book outside the door. Link to comment Share on other sites More sharing options...
Naegele Posted January 27, 2020 Share Posted January 27, 2020 Has anyone found a source for the little suction cups and clips? One of ours got pulled out and the clip disappeared. Link to comment Share on other sites More sharing options...
Patriot Posted January 27, 2020 Share Posted January 27, 2020 Very nice work! 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Link to comment Share on other sites More sharing options...
Trainman Posted February 3, 2020 Share Posted February 3, 2020 We just used the stick on hooks and a Walmart inexpensive shower curtain, works great and we do not leave it up when not in use. We have found that taking showers in the campground facilities is much easier and I can stay in there for a long time, plus have more room to move around. I have found that using RV cramped showers are just too small to feel like I got clean and drying the shower was just work I didn't want to do. I believe in the KISS system. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Link to comment Share on other sites More sharing options...
Kgeb Posted April 7, 2020 Author Share Posted April 7, 2020 On 1/26/2020 at 6:39 PM, Naegele said: Has anyone found a source for the little suction cups and clips? One of ours got pulled out and the clip disappeared. I ordered the suction cups from Amazon they are called "Outus" clear plastic suction cups -22mm. I also found the hairpin clip but will need to research again. Link to comment Share on other sites More sharing options...
