Leak
Water started dripping from the curbside rear speaker. I removed the speaker, panel in the attic and some of the insulation inside the cupboard. Source seems to be the center break light or maybe the back-up camera. I cannot tell just yet because the leak is slow. It’s been going on a while, it’s wet under the cupboard mat.
Anyone else had this problem?
#198
We've had to reseal the upper brake light a couple times over the last 12 years.
Sherry
Found this ....as a past post on that issue.
Hopefully this “leak” at the Oliver logo light will not be an issue with the 2020 Oliver Elite ll we have on order. Thank you ctshort09 for reposting this info.
Edited by Patriot
2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka- Beast
I doubt it will happen at pickup, or in the first severalyears.  Our first leak at the light was 6 or 7 years in, as i recall   Stuff happens. Hulls flex, over the miles.
Leaks around lites/ ports  happen on our 40 plus year old sailboat, usually at the smallest, tightest radiuses, earlier.  The added issue with the third tail light on the Oliver is no real eyebrow, on our older elite.
Maybe next year, when we update some of the eyebrow/ rv gutter material, we'll  add a little strip above. So far, so good. Every six years for a reseal is not a really big deal.
Sherry
Ran into a fellow Oliver owner at the Casita Rally in Grapeland, Texas last year and he had the same problem, turned out to be the seal around the A/C unit. He said, the seal was installed improperly, required removing the A/C unit and reinstall with a new seal. Hope this isn't your problem, but there are very few things that can leak on the roof of the Oliver.
trainman
