DJM Posted March 10, 2020 Share Posted March 10, 2020 I just took delivery on a 2016 Oliver Elite II. It has and Anderson Anti sway hitch. I will be towing it with a 2016 Grand Cherokee with a 5.7 liter V8 and a factory tow package and a brake controller. Various people have told me I don't need the Anderson hitch and I can tow it quite effectively with the bull dog hitch. The transporter brought it to Saint Louis from California without an Anti sway hitch. Why would I need the anti sway hitch? Seems a lot simpler without it. Any advice is appreciated. If anyone can refer me to a URL that discusses this that would be great. Oliver Elite II hull # 151 Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted March 10, 2020 Moderators Share Posted March 10, 2020 There are a number of owners towing with an SUV. The ones with the Audi Q7 and VW Touareg tow without the Andersen because the manufacturer says don’t use a WDH. There are also half ton truck owners towing without the Andersen. I would check to see how your suspension handles the tongue weight when you set the trailer on your hitch. The Andersen can correct any excess dip you may have. Airbags work too. I’ve not towed without the Andersen. I got it for my first truck, a Tacoma, then just kept using it on my two Rams. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted March 10, 2020 Moderators Share Posted March 10, 2020 DJM - I'm presently looking at the 2019 Tow Ratings in the 2019 Good Sam Guide To Towing. Obviously this may or may not apply specifically to your 2016 Grand Cherokee but I suspect the numbers are close (see your Owner's Manual). For the 4 wheel drive model with the 5.7 liter V-8 the tow limit is 7,200 pounds. So, it appears that you will be OK on that front unless you put way too much "stuff" in your Ollie. However, the number that "gets" most of us on the decision to use a weight distribution hitch(WDH) (or not) is the hitch weight. This Good Sam towing guide does not address this point and it is this hitch weight that causes most users of 1/2 ton trucks and similar SUV's to have to use a WDH. In the case of Ford a WDH is required if the hitch weight is over 500 pounds even though my F-150 has a tow rating of over 12,000 pounds. Besides the legal and/or liability issues relating to using or not using a WDH one should also consider the other benefits of WDH usage. These include the potential for a more consistent and level ride, reduced "Porpoising" (the bouncing of the tow vehicle and trailer usually caused by interstate expansion joints), and as an additional safety measure in the event of emergency driving situations. Bill 3 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
Galway Girl Posted March 10, 2020 Share Posted March 10, 2020 Adding on to Topgun2 comment: As you know there are a few parts to the full lashup. The receiver that is on your tow vehicle...it has a rating... The hitch assembly that plugs into that receiver...various classes Weight Distribution Assembly ( bars or in the case of Anderson the torsion chains) Anti Sway Device - (sometimes slider bars, in the case of anderson the Hitch Ball is in a sleeve which provides anti sway.) You may want to look in your manual and at the actual receiver and see if there is a tag like the one below from our F150. In our case, it was on the body of the hitch receiver. It states the hitch capacity towing with or without with a weight distribution setup. For the example below it says specifically if you are towing * without a weight distribution hitch it has a 500 LB MAX tongue wt. * with a weight distribution hitch it has a 1220 LB MAX tongue wt. My Elite II has a 630 LB tongue wt so I must use the WDH to avoid overloading that actual receiver assembly. Hope that helps...set context ctshort09 (Galway Girl) 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Link to comment Share on other sites More sharing options...
Trainman Posted March 11, 2020 Share Posted March 11, 2020 My personal feeling is anything under a 3/4 ton pickup needs a WDH for towing the Oliver. There are many vehicles that people are using for tow vehicles and not using a WDH, will they work, yes on paper they say they will work, but good towing sense says, get the WDH and add a good safety margin above and beyond the factory specs that are for your vehicle. trainman 1 1 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Link to comment Share on other sites More sharing options...
Patriot Posted March 11, 2020 Share Posted March 11, 2020 (edited) 8 hours ago, Trainman said: My personal feeling is anything under a 3/4 ton pickup needs a WDH for towing the Oliver. There are many vehicles that people are using for tow vehicles and not using a WDH, will they work, yes on paper they say they will work, but good towing sense says, get the WDH and add a good safety margin above and beyond the factory specs that are for your vehicle. trainman I agree with trainman. When it comes to safety in general, I would much rather have it and possibly never need it, than need it and wish I had it. I prefer to error on the side of caution. Enjoy that beautiful Ollie and Happy Camping! -Patriot Edited March 11, 2020 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Link to comment Share on other sites More sharing options...
John E Davies Posted March 11, 2020 Share Posted March 11, 2020 (edited) Use the hitch, at least for first few trips. Then you can disconnect the chains and see how it feels without them. I bet you and your passengers will like it a whole lot better with the Andersen hooked up, especially on deteriorating, choppy freeways. https://auto.howstuffworks.com/auto-parts/towing/equipment/hitches/towing-weight-distribution-systems.htm FYI: Your 2016 GC has a 115 " wheelbase. The shortest 2016 F150 Supercab or Crew model is 145", and they go up to over 160". My heavy body-on-frame Land Cruiser is even shorter than your Jeep at 112" Even with a super light tongue weight, there is no way I would feel safe towing without the Andersen. Short wheelbase vehicles are inherently way less stable and controllable when used for towing substantially more than their own weight Enjoy your Ollie, do you have some pics you can share? John Davies Spokane WA Edited March 11, 2020 by John E Davies 1 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
BackofBeyond Posted March 11, 2020 Share Posted March 11, 2020 When I switched from my previous 1/2 ton GMC to my 2500 GMC I used the Anderson a few times - mainly for comparison with/without. About the only difference with it - was the rig felt a little more steady, solid at speed, but not much. The 1/2 ton got a lot of benefit with the WDH, and I would have used it religiously. For anyone needing a WDH, I'll let mine go - cheap. I do not have a use for it with the larger truck. RB 1 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible" Link to comment Share on other sites More sharing options...
WhatDa Posted March 11, 2020 Share Posted March 11, 2020 Check to make sure you don't violate the: Tow Rating TV Gross Vehicle Weight Rating TV Gross Rear Axle Weight Rating TV dead hitch rating Our Lincoln Navigator L (aka Expedition MAX) was OK on all 4 when I shifted weights around enough. It still felt MUCH better with the Anderson on and I didn't have to worry as much about how precisely I was at 10% on the tongue weight. 2 Between Olivers… Link to comment Share on other sites More sharing options...
Patriot Posted March 11, 2020 Share Posted March 11, 2020 (edited) 4 hours ago, John E Davies said: Use the hitch, at least for first few trips. Then you can disconnect the chains and see how it feels without them. I bet you and your passengers will like it a whole lot better with the Andersen hooked up, especially on deteriorating, choppy freeways. https://auto.howstuffworks.com/auto-parts/towing/equipment/hitches/towing-weight-distribution-systems.htm FYI: Your 2016 GC has a 115 " wheelbase. The shortest 2016 F150 Supercab or Crew model is 145", and they go up to over 160". My heavy body-on-frame Land Cruiser is even shorter than your Jeep at 112" Even with a super light tongue weight, there is no way I would feel safe towing without the Andersen. Short wheelbase vehicles are inherently way less stable and controllable when used for towing substantially more than their own weight Enjoy your Ollie, do you have some pics you can share? John Davies Spokane WA John, That link was extremely helpful for someone like me who is new to weight distribution hitches. Thank you for posting, David Edited March 11, 2020 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Link to comment Share on other sites More sharing options...
