BackofBeyond Posted March 13, 2020 Share Posted March 13, 2020 (edited) Like many Oliver owners, and forum lurkers - I repack my own wheel bearings, grease the chassis, and anything else that needs doing. Recently I did my wheel bearings, Dexter has a decent video on the topic if your so inclined, and I ended up replacing both sets on the left side of my Oliver. Once I clean them really well - I do a close inspection to ensure they are good to go back on. I found some indication of damage - these are the bigger inside bearings. If you look opposite the black dot- between the black lines you can see what I'm referring to. You cant see it, but where the indention is on the top side between the rollers is a polished spot, indicating it rubbed on the bearing race. I'm not sure if they were manufactured this way, or if damaged during assembly. I put new Timken's in their place. So perhaps some of the failings we have read about may have come about from this sort of longer term wear. These had 13K miles on them, the bearing cups/races looked fine. Hope this is of interest to ya'll. RB Edited March 13, 2020 by BackofBeyond complee 2 3 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible" Link to comment Share on other sites More sharing options...
Geronimo John Posted April 26, 2020 Share Posted April 26, 2020 I have averaged about 8500 trailer miles for each of the past two years. I do my own R&R as well and use the synthetic lubricant that John D. recommended a year or two ago. My original bearings look good, and I just replaced the seals with Timken made (National) ones. I have a spare set of bearings and seals on board just in case. They were purchased from an authorized Timken distributor. They were not inexpensive..... All that said, at what mileage or age point is a bearing change recommended "just because"? Thanks, 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DYI’s: BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DYI’s: 2 5/16" Anderson System, Timken Bearings, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all. Link to comment Share on other sites More sharing options...
John E Davies Posted April 26, 2020 Share Posted April 26, 2020 (edited) 5 hours ago, Geronimo John said: I have averaged about 8500 trailer miles for each of the past two years. I do my own R&R as well and use the synthetic lubricant that John D. recommended a year or two ago. My original bearings look good, and I just replaced the seals with Timken made (National) ones. I have a spare set of bearings and seals on board just in case. They were purchased from an authorized Timken distributor. They were not inexpensive..... All that said, at what mileage or age point is a bearing change recommended "just because"? Thanks, There is no guidance on a replacement interval. It is a judgement call by the tech or owner who does the job. I personally would want to trash the original cheaply made bearings by 15,000 miles. Mine are OEM and have been repacked once, and in my mind are are due now (12,000 miles). I have Timkens and good seals ready to go. Once you have high quality parts installed, I would let them go indefinitely with regular visual inspection and lubing at about a 10k interval. I think it is really important to watch for signs of distress - play and overheating, grease leakage, funny noises - and be ready to act right away in case there is trouble. Having a seal leak and screw up one brake will ruin a trip. The brake may lock up, making it impossible to tow the trailer without adjusting the controller really low. Which makes it dangerous if your TV has marginal brakes. Disc brakes have huge advantages over drum brakes in so many ways. The biggest one IMHO is that a failed seal will just dump grease outside the hub, not all over the brake mechanism. Once you contaminate one drum brake, they must be replaced in pairs. What a stupid design..... John Davies Spokane WA Edited April 26, 2020 by John E Davies 1 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Geronimo John Posted April 26, 2020 Share Posted April 26, 2020 John D. Very well said. Mahalo! 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DYI’s: BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DYI’s: 2 5/16" Anderson System, Timken Bearings, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all. Link to comment Share on other sites More sharing options...
dewdev Posted February 3, 2021 Share Posted February 3, 2021 (edited) My 2018 Elite II has about 8,000 miles on it. I am thinking that maybe I should check the bearings at around 16,000 miles. What do others recommend for the amount of miles to check the bearings? I would like to purchase some Timken's bearings and seals to have on hand. What size are the bearings and seals on the Elite II? Better still - what are the Timken part numbers? Are they available at automotive stores like NAPA? Thanks Richard Edited February 3, 2021 by dewdev 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio Maine Link to comment Share on other sites More sharing options...
mjrendon Posted February 3, 2021 Share Posted February 3, 2021 Richard, Check this thread for the information you requested. Mike Link to comment Share on other sites More sharing options...
BackofBeyond Posted February 3, 2021 Author Share Posted February 3, 2021 1 hour ago, dewdev said: My 2018 Elite II has about 8,000 miles on it. I am thinking that maybe I should check the bearings at around 16,000 miles. What do others recommend for the amount of miles to check the bearings? I would like to purchase some Timken's bearings and seals to have on hand. What size are the bearings and seals on the Elite II? Better still - what are the Timken part numbers? Are they available at automotive stores like NAPA? Thanks Richard Richard, I cannot remember what the interval quoted in the manual states - but I grease mine at least twice a year - depending on mileage, and once a year - again depending on mileage, - clean and repack the bearings. As for authentic Timken's - I would find a reputable dealer - most auto supply house will probably have to order, a good bearing supply dealer will have them. I used Amazon- will not next time. I replaced one side because under inspection I found a slight deformity - in all reality it would most likely have been fine. Some folks are more inclined to shorten the interval, some go the other way - I just try to use distance on the bearings to decide the interval. Quite honestly - if I was not running about the country - and stayed relatively close to home - I would double this interval. I have yet to do my farm use tandem axle bearings - in 7 years - greased them a few times..... Mike pointed you to the posts. with all the needed info. Good travels RB Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible" Link to comment Share on other sites More sharing options...
JRK Posted February 6, 2021 Share Posted February 6, 2021 I have looked through the manual in the University, but do not see the model number for wheel bearings. Which Timken bearings/seals would I buy for an Elite I, single axle? I'll be putting about 5,000 miles on the trailer before I get home after picking up in March. I plan to have replacements for such items that might wear out/fail that will prevent me from driving, such as wheel bearings. Thanks John 2014 Toyota Tacoma 4x4 2021 Elite I #758 Link to comment Share on other sites More sharing options...
rideandfly Posted February 6, 2021 Share Posted February 6, 2021 John, Jason can confirm you have a 5200 pound Dexter axle on a new manufacture Legacy Elite single axle trailer. Our LE2 has 5200 pound Dexter axles. Took the following Dexter bearing/seal numbers off of our Dexter axle build sheet. Crossed the Dexter numbers over to Timken & Chicago Rawhide numbers. Dexter also has a build sheet with brake, seal, bearing, and dimension information available for your axle when you give Dexter the axle serial number stamped on the axle. 2 Each Bearings Dexter # 031-029-02 or Timken # 15123 2 each Bearings Dexter #031-030-02 or Timken #25580 2 each Seals Dexter #010-036-00 seal or CR #22532 Hope this helps, 1 LE2 Link to comment Share on other sites More sharing options...
NCeagle Posted February 6, 2021 Share Posted February 6, 2021 For anyone buying bearings from any manufacturer online, there's a relatively new app from the World Bearing Association that helps identify counterfeits. Search "WBA Bearing Authenticator". I used it recently on my ipad (IOS) and I think it's also available for Android. 1 2 2020 Elite II, Hull 688 --- 2021 Silverado 2500HD, 6.6L Duramax Diesel Link to comment Share on other sites More sharing options...
JRK Posted February 7, 2021 Share Posted February 7, 2021 Helps a lot thanks john 2014 Toyota Tacoma 4x4 2021 Elite I #758 Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted February 7, 2021 Moderator+ Share Posted February 7, 2021 On 2/5/2021 at 9:02 PM, rideandfly said: 2 Each Bearings Dexter # 031-029-02 or Timken # 15123 2 each Bearings Dexter #031-030-02 or Timken #25580 2 each Seals Dexter #010-036-00 seal or CR #22532 Hope this helps, These are the correct bearing and seal Part Numbers for all the Elites and the VERY FEW Elite II's that are equipped with 5200 pound axles. 1 Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
Pat Maundrell Posted February 11, 2021 Share Posted February 11, 2021 Don't new Olivers use the "Never Lube" Dexter Axles? Link to comment Share on other sites More sharing options...
Overland Posted February 11, 2021 Share Posted February 11, 2021 (edited) 12 minutes ago, Pat Maundrell said: Don't new Olivers use the "Never Lube" Dexter Axles? Correct, starting this year. I have them on mine and they're zero maintenance other than occasionally checking for any leakage or play in the bearing. You'll still have to lube the suspension bushings, however. Edited February 11, 2021 by Overland Link to comment Share on other sites More sharing options...
BackofBeyond Posted February 15, 2021 Author Share Posted February 15, 2021 On 2/11/2021 at 11:02 AM, Overland said: Correct, starting this year. I have them on mine and they're zero maintenance other than occasionally checking for any leakage or play in the bearing. You'll still have to lube the suspension bushings, however. I am always a little wary of never lube - but then - what do I know. 2 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible" Link to comment Share on other sites More sharing options...
Fargoman Posted February 15, 2021 Share Posted February 15, 2021 Hi Overland, Are the Dexter Nev-R-Lube axles on your trailer a retrofit? I contacted Jason about the possibility of the Nev-R-Lube axles being available in time for the September 2021 delivery date for my Elite 2. He replied that it would depend on when Oliver starts installing them on the 2022 models, and if there is a good supply, as they are currently experiencing problems with vendors being able to meet demand. 2021 Legacy Elite 2 Twin Bed | Hull Number 894 (9/16/21 delivery) | Ram 1500 Longhorn 4x4 3.0L EcoDiesel 3.92 axle Link to comment Share on other sites More sharing options...
Overland Posted February 15, 2021 Share Posted February 15, 2021 15 minutes ago, Fargoman said: Are the Dexter Nev-R-Lube axles on your trailer a retrofit? No, they were part of a one-off disk brake experiment Oliver did for me. 1 Link to comment Share on other sites More sharing options...
Fargoman Posted February 15, 2021 Share Posted February 15, 2021 Thanks Overland, Your earlier post where you stated that the Nev-R-Lube axles would be available "starting this year" made me hopeful that our trailer would have those axles, but Jason's reply that "it will depend on when the plant starts installing them on 2022 models and if there is a good supply" made me question that. Do you know what Oliver considers a 'model year' - began production in, or delivered in a given year? We ordered our Ollie in November 2020, understanding that production and delivery would happen sometime in 2021, making our Ollie a 2021 model. 2021 Legacy Elite 2 Twin Bed | Hull Number 894 (9/16/21 delivery) | Ram 1500 Longhorn 4x4 3.0L EcoDiesel 3.92 axle Link to comment Share on other sites More sharing options...
quoyle Posted July 11, 2022 Share Posted July 11, 2022 I have a 2019 Elite I (purchased Oct 29,2019). Would the bearing/seal numbers be the same for my model year? If not how could I find them? many thanks.. tom 2 Each Bearings Dexter # 031-029-02 or Timken # 15123 2 each Bearings Dexter #031-030-02 or Timken #25580 2 each Seals Dexter #010-036-00 seal or CR #22532 Link to comment Share on other sites More sharing options...
Ghostriderc227 Posted July 12, 2022 Share Posted July 12, 2022 These had 13K miles on them, the bearing cups/races looked fine. RB, Not certain if you replaced the bearings AND the bearing races. I do hope you replaced both the race and bearing. Just replacing the bearing is not a good idea. Steve. 3 2015 Oliver Elite 2 Hull #106 2019 Ford F-250 Super Duty, 6.7 diesel Link to comment Share on other sites More sharing options...
John E Davies Posted July 12, 2022 Share Posted July 12, 2022 36 minutes ago, Ghostriderc227 said: Just replacing the bearing is not a good idea. This is a great point, not only is it not a good idea, it is very bad. A used race with a new bearing will probably cause failure in a short time because the used one has some wear, even if it isn’t visible... New Timkens are sold as matched sets, meaning the two parts were machined for a (nearly) perfect fit. Cheap poor quality no-name ones, especially counterfeits, most likely were not, even if they come packed in the same box or blister pack. It is definitely a buyer beware situation. Don’t be a cheapskate if you tow a lot of miles, and never be one if you tow in really remote locations. Also, keep the removed bearings separated, keep track of where they came from so you don’t accidentally install one into the the wrong wheel! That actually means you installed two wrong ones, with two possible failures! I put a blue paper shop towel on the ground at the axle and put the drum and the removed bearings on it, then I take the parts to my bench to clean, lube or replace one set at a time. That greatly reduces the chance that you will have a “senior moment”. But that can still happen, I recently drove in my last inner seal backwards. 😳 I caught my mistake right away but I had to drive to a bearing store for a replacement, and to buy a spare… John Davies Spokane WA 5 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
