Daecart Posted June 14, 2020 Share Posted June 14, 2020 I noticed in the Oliver Manual Maintenance Schedule that monthly I should be Lubricating the Waste Blade Valve. Slight problem, I dont know what or where that is or how to lubricate it. I searched the forums but can't find any mention. Does anyone have more details about this or does it monthly and can outline a procedure? (I have a '18 LE 2) Link to comment Share on other sites More sharing options...
Patriot Posted June 15, 2020 Share Posted June 15, 2020 (edited) We are new very soon to be Ollie owners. In learning from members on this forum and other Ollie owners locally this is a good product to add to your black and gray tanks to help with lubing the blade valves you mention. Other owners will hopefully chime in. I have a few bottles of this and plan to use it per manual directions. I am sure there are other products out there, but this was highly recommended to me by a few Ollie owners/friends it has decent reviews. Edited June 15, 2020 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Link to comment Share on other sites More sharing options...
Daecart Posted June 15, 2020 Author Share Posted June 15, 2020 18 minutes ago, Patriot said: We are new very soon to be Ollie owners. In learning from members on this forum and other Ollie owners locally this is a good product to add to your black and gray tanks to help with lubing the blade valves you mention. Other owners will hopefully chime in. I have a few bottles of this and plan to use it per manual directions. I am sure there are other products out there, but this was highly recommended to me by a few Ollie owners friends. It has decent reviews. Hope this helps. Thanks, Patriot. I was just outside lubricating the zerks in the Dexter E-Z Flex, so my mind was thinking something totally different by way of lubrication. I will give this product a look. It has to be easier than crawling under the trailer with a grease gun!!! Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted June 15, 2020 Moderators Share Posted June 15, 2020 Yep - that's the stuff (there are a couple of brands that are similar). I only use it a couple times a year and all seems to operate smoothly. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
Frank C Posted June 16, 2020 Share Posted June 16, 2020 (edited) Ditto on the Thetford drain valve lubricant. We've been using it for the last year on our Ollie. I typically just pour a bit down the sink drains on each camping trip. There is also another lubricant from Thetford specifically for the seal on the flush toilet that you pour in the toilet and let sit for 8 hours or so (Thetford RV Toilet Seal Lube & Conditioner). I use that as well on the day before we leave for any of our trips and let it sit. So far no problems with any of the seals or valves. Edited June 16, 2020 by FrankC Link to comment Share on other sites More sharing options...
hardrock Posted June 17, 2020 Share Posted June 17, 2020 (edited) The actual blades, black and gray, are lubricated when you apply the drain valvelubricant. However, you may find despite adding the blade lubricant, the valve becomes difficult to open/close. The cable occasionally needs to be greased. Not real difficult, but not easy to undo the cable, slide it out, put white lithium grease on it and put it back. The valve handle / cable will be much easier, so know that if the valve may feel stuck/sticking, it may be your cable. good luck coy Edited June 17, 2020 by hardrock misspelling 2 Link to comment Share on other sites More sharing options...
GarryandKristi Posted June 28, 2020 Share Posted June 28, 2020 (edited) On 6/16/2020 at 11:01 PM, hardrock said: The actual blades, black and gray, are lubricated when you apply the drain valvelubricant. However, you may find despite adding the blade lubricant, the valve becomes difficult to open/close. The cable occasionally needs to be greased. Not real difficult, but not easy to undo the cable, slide it out, put white lithium grease on it and put it back. The valve handle / cable will be much easier, so know that if the valve may feel stuck/sticking, it may be your cable. good luck coy I agree that the real problem is the cable. I did lube the gate channels by loosening the screws and dosed with a spray can straw with some lithium or silicone spray (don’t remember exactly). It worked for a few operations then back to the default of being about 1/4 “ of full bottomed -out closure. The issue is the torturous cable path of the black tank valve with an insufficient straight final run to the slide valve. I haven’t lubed the cable but I think that is the best solution. I tried the coconut oil stuff and it didn’t solve the lack of full closure issue. Another “solution is just to remove the dinette seat and underlying hatch and just push the slide gate fully closed at the center near the cable termination. Edited June 28, 2020 by GarryandKristi Garry and Kristi Apex, NC 2018 Oliver Elite II Hull 372 TV 2015 Ram 1500 3.0 L EcoDiesel Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted June 28, 2020 Moderators Share Posted June 28, 2020 24 minutes ago, GarryandKristi said: Another “solution is just to remove the dinette seat and underlying hatch and just push the slide gate fully closed at the center near the cable termination. This is what we do. I’ve had both cables out to clean and lube. The gate usually closes but we’ve found it a good practice to manually seat it after dumping. Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
