John E Davies Posted July 4, 2020 Share Posted July 4, 2020 (edited) Here is a really interesting discussion of this rugged kit. I wonder how well it could be adapted to an OL2? Because the frame already has a stout steel subframe it should be an ideal platform.... the 3500 pound units use 6000 pound rated spindles and bearings. Woohoo! https://www.off-road.com/blog/timbren-axle-less-trailer-suspension-review/ These sell for $760 per axle at eTrailer. https://www.etrailer.com/Trailer-Leaf-Spring-Suspension/Timbren/ASR35HDS02.html I would go whole hog and add disk brakes at the same time. OTH I would be very reluctant to be the first to do this, from cost and liability reasons. I wonder if the factory would consider building a test mule for high speed highway stability testing and off- pavement testing....? Any idea how hard it would be to completely remove the subframe, do this mod and then reinstall it? It doesn’t appear to be difficult, if it is not bonded too ferociously to the aluminum. I think this would turn an Ollie into a stellar gravel/ washboard trailer. Because the stock springs are incredibly lame for this use. Discuss please. John Davies Spokane WA Edited July 4, 2020 by John E Davies 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Overland Posted July 4, 2020 Share Posted July 4, 2020 (edited) Looks like you’d have to take the subframe off to mount those, which I’m pretty sure means that you have to lift the tub off the frame. Possible, but Oliver would have to do it, which means it’s impossible. They’d never go for it. I think you’d want to beef up the subframe, too, while you’re at it - I don’t think I’d feel comfortable that the existing cross braces are strong enough to take the twisting forces that these would add. I still think the Lippert Centerpoint is the easiest upgrade. Edited July 4, 2020 by Overland Link to comment Share on other sites More sharing options...
John E Davies Posted July 4, 2020 Author Share Posted July 4, 2020 (edited) I guess I need to go out and lie down on a piece of cardboard and look closer. Why does the hull have to come off?That seems like a really awkward design feature.... You wouldn't necessarily have to remove it, though fabrication would be a whole lot easier with it upside down on supports. You would have to grind off the spring hangers and maybe the shock mounts. It is super easy to reinforce the Timbren units - you just add a length of 2x3” steel tubing between the existing sockets. It fits up high, giving about 5 more inches of clearance than a straight axle. The Lippert system will not do a thing to correct the severe lack of vertical travel of each wheel. On my trailer there is just 1.5” of up travel before the ubolts contact the subframe. The Timbrens have about 3” up and (the article says) a total of 4”. Not great by offroad standards, but way better than the Dexter springs. And it is progressively dampened, so no more banging and crunching.... I like simple, low maintenance designs. The Timbren meets that criterion. A tandem installation has just four grease fitting, for the pivot bushings. The Dexter EZ Flex is really complex with its 20 zerks and four leak prone shock absorbers. it is a messy PITA. John Davies Spokane WA Edited July 4, 2020 by John E Davies 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Overland Posted July 4, 2020 Share Posted July 4, 2020 (edited) You’re right. For some reason I was thinking that the bolts on mine faced outward, meaning you’d have to pull the hull to get them out of the hole. But I just checked and they face in. The Centerpoint does add 1” to the travel. Edited July 4, 2020 by Overland 1 1 Link to comment Share on other sites More sharing options...
John E Davies Posted July 4, 2020 Author Share Posted July 4, 2020 (edited) 1 hour ago, Overland said: The Centerpoint does add 1” to the travel. Does it actually provide a lift? Because that is the only way you would gain any extra upward travel on an Ollie John Davies Spokane WA Edited July 4, 2020 by John E Davies SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Overland Posted July 4, 2020 Share Posted July 4, 2020 (edited) That’s what they say. eTrailer says it’s actually 2”. Edited July 4, 2020 by Overland Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted July 4, 2020 Moderator+ Share Posted July 4, 2020 I would be willing to install this just to eliminate all the grease zerks. 4 Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
John E Davies Posted July 6, 2020 Author Share Posted July 6, 2020 (edited) I just looked closer at “Mouse”, and the subframe mounting bolt heads are facing out, so they are blocked by the fiberglass. I sure wouldn’t pull off the hull, tho, I would just drill access holes in that lower fiberglass lip. But in reality, I think having the trailer up high on a hoist in a proper shop would provide very easy access, to cut off the shackle and shock mounts, and to trim some of the cross angle-iron braces. Counting the removal time for the straight axles, I bet the entire conversion could all be done by a pro with a plasma cutter in half a day. It could all be done by the owner with a saber saw and angle grinder while lying on the ground, but that is a job I probably would not enjoy, not even a little bit. 😳 Oliver could easily do this at the factory as a pre-build option. They would just need to have a few extra subframes lying around, ones with galvanized finish but without the brackets and hangers. Installation labor on the production line would be minimal. Considering that they buy the parts at wholesale and the buyer would get a credit for not installing the EZ Flex axles, springs and four shocks, I think a $2000 price tag for a factory Timbren option (with Dexter electric brakes) would be very reasonable. Would you pay $2000 for this setup? I definitely would. John Davies Spokane WA Edited July 6, 2020 by John E Davies 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Overland Posted July 6, 2020 Share Posted July 6, 2020 That’s interesting. I thought I remembered seeing a photo of an Oliver with the bolts facing the other way, which is why I was surprised to see that mine weren’t. I guess Oliver just wasn’t consistent with how they were installed. I wonder if it would be possible to get a grinder between the hull and frame to cut off the bolt heads then pull them through. 1 Link to comment Share on other sites More sharing options...
FJV Posted September 30, 2020 Share Posted September 30, 2020 Jason, Oliver sales rep, sent the standard email after I downloaded the build sheet for the Elite. I provided the timbren web site. Stated I would be happy to purchse an Elite built with the Timbren units. No further contact from Jason. 1 Link to comment Share on other sites More sharing options...
Overland Posted September 30, 2020 Share Posted September 30, 2020 (edited) Highly unlikely that you'll get Oliver to make that change. It's a DIY job for sure. Besides, Oliver's m.o. for the past two or three years has been to carefully study what owners want, have researched, implemented, are satisfied with, etc., and then do something different. Edited September 30, 2020 by Overland 4 1 Link to comment Share on other sites More sharing options...
John E Davies Posted September 30, 2020 Author Share Posted September 30, 2020 21 minutes ago, Overland said: Besides, Oliver's m.o. for the past two or three years has been to carefully study what owners want, have researched, implemented, are satisfied with, etc., and then do something different. 😀 Well said, but we should keep trying with stuff like this. At some point, maybe when RV sales are in a deep slump, they will decide to offer more “adventurous” options for us, the fringe market. It certainly does NOT hurt to keep asking. John Davies Spokane WA 1 4 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
bhncb Posted September 30, 2020 Share Posted September 30, 2020 40 minutes ago, FJV said: No further contact from Jason. You won't find any production trailer manufacturer willing to make one-off modifications this extensive. Oliver and others have limited to no engineering capabilities, instead relying on component suppler services, like Dexter, for this expertise. For an Elite, you're talking about a complete sub-frame redesign. 1 3 Link to comment Share on other sites More sharing options...
Overland Posted September 30, 2020 Share Posted September 30, 2020 (edited) 2 hours ago, John E Davies said: It certainly does NOT hurt to keep asking. I agree. But putting my snarky comments aside, I think there are many other areas that Oliver could and should put their efforts into before they ever try to tackle the offroad market. And even if I limited my wishes to just offroad and boondocking related items, the suspension would be pretty low on my list. Edited September 30, 2020 by Overland 2 Link to comment Share on other sites More sharing options...
Landrover Posted October 1, 2020 Share Posted October 1, 2020 If anyone is that serious to have a extreme off road trailer. Do as Raspy did buy a Black series trailer. Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted October 1, 2020 Moderators Share Posted October 1, 2020 11 minutes ago, Landrover said: anyone is that serious to have a extreme off road trailer. Do as Raspy did buy a Black series trailer. Actually, for serious Aussie outback, I like everything about the Bruder, except the 100k+ price tag, of course. 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
bhncb Posted October 1, 2020 Share Posted October 1, 2020 1 hour ago, SeaDawg said: except the 100k+ price tag, of course. Priced a Kimberly Kruiser? Ouch! Link to comment Share on other sites More sharing options...
Overland Posted October 1, 2020 Share Posted October 1, 2020 The Bruders are definitely interesting, but I’ve never figured out how their kitchen arrangement works for both inside and out, height wise. We seriously considered importing an Aussie trailer before we bought an Ollie. But then we ran across some owners with bad experiences and no options for a remedy - structural issues that couldn’t be fixed without sending the trailers back to Australia. Prior to that, we were looking into a heavily hyped teardrop that looked the part in every way; but as it turned out, the owner was taking big deposits left and right without any skill in how to actually produce them. Fortunately, in both instances we found out before parting with any money. Both companies later went bankrupt. Just goes to show that the basics really count. There’s a lot of eye candy out there but always ask two questions before you buy: one, is the company stable, experienced, reliable, and do they stand behind their product; and two, do they make a product that is at the most basic level solid, durable, and thoughtfully designed? If you can answer both of those questions with an unconditional ‘yes’, then give them your money. The details will work themselves out. But if the answer to either question is ‘no’ or ‘no idea’, then give it a hard pass. 3 Link to comment Share on other sites More sharing options...
John E Davies Posted March 14, 2021 Author Share Posted March 14, 2021 (edited) Updating an older thread - here is a great install video from etrailer.com. Install Timbren Axle-less Trailer Suspension The more I read and watch, the more I think that this would be a great low maintenance option for an Ollie, for lumpy forest and ranch roads. The thing that worries me most is that I haven’t read any reviews for tandem trailers. How does this system perform, are there any sway concerns, or tire overloading issues? A standard tandem spring setup equalizes the tire loads, this would not. I think this would be a great winter project, along with electric over hydraulic disk brakes, but I still am not ready to assume all the R&D risks. That is something for the Hohenwald team to do..... please! John Davies Spokane WA Edited March 14, 2021 by John E Davies 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Overland Posted March 14, 2021 Share Posted March 14, 2021 (edited) Or just install the centerpoint suspension like I did and be done with it. Takes all of an afternoon. I ended up with about an inch more travel plus the extra cushioning. Of course, you can adjust the height by changing the pressure. It's a good, practical solution. Edited March 14, 2021 by Overland 2 Link to comment Share on other sites More sharing options...
Cort Posted August 31, 2023 Share Posted August 31, 2023 On 3/14/2021 at 4:44 PM, Overland said: Or just install the centerpoint suspension like I did and be done with it. Takes all of an afternoon. I ended up with about an inch more travel plus the extra cushioning. Of course, you can adjust the height by changing the pressure. It's a good, practical solution. Is this it? https://store.lci1.com/center-point-air-ride-suspension-system-center-point 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner). Link to comment Share on other sites More sharing options...
John E Davies Posted August 31, 2023 Author Share Posted August 31, 2023 Yikes: I call that sophisticated monkey motion: far FAR too complicated for the end result. (Like drum brakes vs disc brakes.) This is the complete opposite of low maintenance. You still have all those grease fittings to worry about, plus the complexity of the airbag equalizers, and the possibility of leaks or stone damage from debris spit out by the tow vehicle’s rear tires. John Davies Spokane WA 1 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Moderators bugeyedriver Posted August 31, 2023 Moderators Share Posted August 31, 2023 2 hours ago, John E Davies said: Yikes: I call that sophisticated monkey motion . . . John Davies You have a way with words, John. Ha! 2 1 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com Link to comment Share on other sites More sharing options...
MAX Burner Posted September 1, 2023 Share Posted September 1, 2023 On 9/30/2020 at 7:51 PM, SeaDawg said: Actually, for serious Aussie outback, I like everything about the Bruder, except the 100k+ price tag, of course. Woah! Looks like they're almost in the $200k range now - you could buy two OTTs and have one as a hangar queen for spare parts. Theoretically, making your TT last twice as long! HA! 1 Art, Diane, Oscar & Magnus (double-Aaarrf!) 2022 TUNDRA w/Airlift Load Lifter 5000 kit/2017 LE II; Hull #226 "Casablanca", 12VDC Starlink kit, 3x Battle Borns; Victron Cerbo GX, SmartShunt, MPPT Solar Controller, & DC-DC Charger; HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
abcsfam Posted September 2, 2023 Share Posted September 2, 2023 I had a cruisemaster CRS2 installed on my overland trailer and Wow! I’m not sure my Ollie needs to be abused like that though. https://cruisemaster.com.au/crs2/ 2 Link to comment Share on other sites More sharing options...
