SteveC Posted October 11, 2020 Share Posted October 11, 2020 Our right brake, turn and flasher is out. Left works fine. TV plug checks good and TT connector is good. Hull #428 2019 , do led’s burn out? Does the trim ring on fixture pop off to check fixture or do you have to access through bunk locker? Any help appreciated,thanks. Link to comment Share on other sites More sharing options...
John E Davies Posted October 11, 2020 Share Posted October 11, 2020 I am not sure about the bezels. My guess is that they do come out by careful prying with a plastic body tool, not a steel tool! Maybe a call to Service would be a good next step, if you can wait until Monday..... You have a wiring issue if it affects both light units. If just one, then it could be a light failure. LEDs do fail at random, but never all at once. Boards and soldered connections however do fail, possibly rendering the entire unit dead. Good luck. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
BackofBeyond Posted October 11, 2020 Share Posted October 11, 2020 I had a left lower running light start blinking - Oliver replaced it - said it had gone bad..... I thought it was good for many many years... Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible" Link to comment Share on other sites More sharing options...
SteveC Posted October 11, 2020 Author Share Posted October 11, 2020 11 hours ago, John E Davies said: I am not sure about the bezels. My guess is that they do come out by careful prying with a plastic body tool, not a steel tool! Maybe a call to Service would be a good next step, if you can wait until Monday..... You have a wiring issue if it affects both light units. If just one, then it could be a light failure. LEDs do fail at random, but never all at once. Boards and soldered connections however do fail, possibly rendering the entire unit dead. Good luck. John Davies Spokane WA Thanks for input John, we are safely home but heading out Friday for a few days. I agree with you assessment and will call Jason tomorrow at Oliver. I feel sure it’s a simple fix I just don’t know the steps....yet! Link to comment Share on other sites More sharing options...
