Jairon Posted November 9, 2020 Share Posted November 9, 2020 (edited) I did some digging for a few hours and gave up. Web filters for storage bin sizes seem to fail on almost every online retailer I've tried. I'm looking to fill the area directly behind the outdoor access panel. Edited November 9, 2020 by Jairon 2019 Toyota Land Cruiser 2021 Oliver Elite II, Hull #748 Link to comment Share on other sites More sharing options...
Jairon Posted November 10, 2020 Author Share Posted November 10, 2020 (edited) Where I'm at after more research: IRIS container confirmed to fit from thread: Size: W:15 11/16" L: 21 5/8" H: 10 11/16" Possible larger alternative that should fit: https://www.irisusainc.com/weathertight-storage-box-46-6-qt-ucb-sd Might be possible with or without the lid. I'm unsure what the actual height is in the basement: https://www.irisusainc.com/sliding-storage-box-61-qt-ssb-60-green I'm going to keep searching but hopefully this will help someone. Edited November 10, 2020 by Jairon 2019 Toyota Land Cruiser 2021 Oliver Elite II, Hull #748 Link to comment Share on other sites More sharing options...
DavidS Posted November 10, 2020 Share Posted November 10, 2020 I posted about the 15 11/16 wide x 21 5/8 long x 10 11/16 high storage box in the earlier thread you noted. The 19.70 x 15.75 x 11.75 storage box you linked to should fit fine. I think the 23.4 x 15.6 x 13.0 Inches storage box would be problematic, as I think the 23.4 inch dimension is too long to fit. I think the dimension is 22 inches until you reach the edge of the twin bed. You probably could rotate it as you put through the door, but then the 15.6 inch dimension would be wasting storage space (22-15.6 inches). David Stillman, Salt Lake City, Utah 2016 Oliver Elite II Hull 164 | 2017 Audi Q7 tow vehicle. Travel and Photography Blog: http://davidstravels.net Link to comment Share on other sites More sharing options...
Jairon Posted November 10, 2020 Author Share Posted November 10, 2020 (edited) 4 hours ago, DavidS said: I posted about the 15 11/16 wide x 21 5/8 long x 10 11/16 high storage box in the earlier thread you noted. Thanks for that very useful post, David. I was hopeful for the 23.4 inch long version based on CedarForks' custom tub design: I was hopeful that with 3.1 inches lopped off the end, it would fit. Rounded corners are tricky though and I have no idea how accurate his drawing is 🤪 Based on Oliver's basement video, the shape looks very different: Edited November 10, 2020 by Jairon 2019 Toyota Land Cruiser 2021 Oliver Elite II, Hull #748 Link to comment Share on other sites More sharing options...
