John E Davies Posted December 13, 2020 Share Posted December 13, 2020 (edited) For those with a technical interest this is useful. Even if you can’t understand much of it, take away this important fact. “... it is common to charge a 12 volt a 4-cell series pack with a lead acid battery charger. The maximum voltage of these chargers, whether AC powered, or using a car's alternator, is 14.4 volts. This works fine, but lead acid chargers will lower their voltage to 13.8 volts for the float charge, and so will usually terminate before the LiFe pack is at 100%. For this reason a special LiFe charger is required to reliably get to 100% capacity.” https://www.powerstream.com/LLLF.htm So maybe a standard automotive portable lead acid charger of adequate size would be a good thing to have as a backup in case your onboard system becomes inoperative..... it won’t fully charge it, but it will get it most of the way there, about 70%. Or for around $120 you can get a 20 amp Renogy unit that will eventually get them to 100%. https://www.amazon.com/Renogy-12V-20A-Alligator-Batteries/dp/B08C2JN76Q John Davies Spokane WA Edited December 13, 2020 by John E Davies 1 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Mcb Posted December 13, 2020 Share Posted December 13, 2020 Thanks for the info John, I emailed the LifeBlue rep this am asking him for his thoughts on the subject of chargers. If my lead acid battery charger could get the batteries partially charged in a reasonable amount of time I think I’ll stick with that. I’d be looking for something to bail me out of a situation while on the road that I can stow in the truck and hopefully never need.. 1 Mark & Deb..2020 Elite II..Dearie..Hull #685..2016 Tundra Link to comment Share on other sites More sharing options...
Moderators mossemi Posted December 13, 2020 Moderators Share Posted December 13, 2020 My backup plan consists of a set of jumper cables. Mossey 1 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
Overland Posted December 13, 2020 Share Posted December 13, 2020 3 hours ago, John E Davies said: ...but lead acid chargers will lower their voltage to 13.8 volts for the float charge, and so will usually terminate before the LiFe pack is at 100%. Do they mean to say absorption rather than float? Battleborn's recommended float charge is 13.6 volts. Link to comment Share on other sites More sharing options...
carnivore Posted December 13, 2020 Share Posted December 13, 2020 Jumper cables or an inexpensive battery charger from Walmart to finish the trip. Link to comment Share on other sites More sharing options...
BackofBeyond Posted December 13, 2020 Share Posted December 13, 2020 On the Sprinter forum (few years back) - one system outlined and used a 2000w inverter, running off the TV system, to power an AC NOCO smart charger. Now - it was all contained within the Sprinter, the inverter wired appropriately - per MB specifications- within about 2' of the Battery/DC buss. The charger was located near the house battery. It worked fine - but- seems a little iffy trying to run an AC circuit between a TV and the RV/battery charger. Properly wire and fused appropriately - perhaps. I'm still in the cheap gen set arena. I can see that changing in 3-4 years - given the rate of techno innovation. RB Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible" Link to comment Share on other sites More sharing options...
Moderators mossemi Posted December 13, 2020 Moderators Share Posted December 13, 2020 1 hour ago, carnivore said: Jumper cables or an inexpensive battery charger from Walmart to finish the trip. The jumper cables were already in my truck so I didn’t have to go to Wally World. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
Jim_Oker Posted December 13, 2020 Share Posted December 13, 2020 Nice to know. I appears I already have a backup system for shore or generator based charging that isn't to big and not heavy at all. Thanks John! Just gotta think through where the clips should go. Jim and Yanna, Woodinville WA 2004 Ford E250 camper conversion Oliver Elite II hull #709 Link to comment Share on other sites More sharing options...
mjrendon Posted December 13, 2020 Share Posted December 13, 2020 (edited) John, Since you are installing an MMPT charge controller, you could disconnect the PVs and plug in the output from a 120V AC to 24V DC converter and have the MMPT controller properly charge your Li batteries. If you are installing dual controllers (one for roof top PVs and one for external PVs) you could easily use the external PV charge controller connector for this too. MMPT controllers can handle 100V DC (some 150V) and 120V AC to 24V DC converters for LED drivers or laptops are inexpensive with 10A, 15A or more current (240 to 360watts). Mike Edited December 13, 2020 by mjrendon 2 Link to comment Share on other sites More sharing options...
NCeagle Posted December 13, 2020 Share Posted December 13, 2020 9 hours ago, John E Davies said: Or for around $120 you can get a 20 amp Renogy unit that will eventually get them to 100%. Or for an even better amps to $ deal, for an extra $100 you can triple the amps and get out of an emergency situation with a 15 Amp generator 3x faster (it's $100 off regular price right now). I have this in my shopping cart but have yet to purchase. https://www.etrailer.com/p-PD9160ALV.html Could be mounted in the basement somewhere and connected to batteries or just use alligator clips and make it "portable" (that's what I'm thinking). 2020 Elite II, Hull 688 --- 2021 Silverado 2500HD, 6.6L Duramax Diesel Link to comment Share on other sites More sharing options...
Overland Posted December 13, 2020 Share Posted December 13, 2020 (edited) 36 minutes ago, mjrendon said: Since you are installing an MMPT charge controller, you could disconnect the PVs and plug in the output from a 120V AC to 24V DC converter and have the MMPT controller properly charge your Li batteries. Interesting thought. I can’t think why this wouldn’t work. Edited December 13, 2020 by Overland Link to comment Share on other sites More sharing options...
mjrendon Posted December 13, 2020 Share Posted December 13, 2020 $20 for 360 watts (after the original MMPT investment of course) 1 Link to comment Share on other sites More sharing options...
