John C Marsh Jr Posted February 11, 2021 Share Posted February 11, 2021 What do others use to help assure the water they use, either from the onboard tank or direct, both from the faucet at an RV park, is potable? In addition to the inline filter, we are considering a Britta counter pitcher, or something similar. Just don’t want to use a bunch of disposable bottles. 1 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted February 11, 2021 Moderators Share Posted February 11, 2021 (edited) Several of us use the Pur. Some use Brita, but I think Pur filters more contaminants. https://www.pur.com/why-pur/filter-comparison-pitcher Edited February 11, 2021 by SeaDawg Add link 1 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Galway Girl Posted February 11, 2021 Share Posted February 11, 2021 Outside we use a 3 stage outboard filter from Clear Source which includes: Stage 1 Sediment, Stage 2 Block Carbon and Stage 3 a 2 u finisher. Inside we're using a Burkee Travel size. 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Link to comment Share on other sites More sharing options...
John E Davies Posted February 11, 2021 Share Posted February 11, 2021 (edited) Three camping seasons now with the Pur, and it continues to impress me. It is an inexpensive solution. Try it for a while, and if you feel the need for a more intensive setup for the trailer, use the pitcher at home or gift it to a relative. John Davies Spokane WA Edited February 11, 2021 by John E Davies 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Frank C Posted April 3, 2021 Share Posted April 3, 2021 (edited) Clean water is one of my OCD issues with camping. 🙂 Hard to believe that as kids, when out playing basketball or baseball we just drank from whatever neighborhood garden hose was available. 🙂 I put together a 3 stage system similar to the ClearSource unit, but for about half the cost. The first stage is the usual Camco bullet style filter that you see everyone using hanging on the campsite faucet. That filter is a 20 micron size filter rating, and pretty decent chemical removal. After that I use a 5 micron cartridge filter and then a 0.5 micron carbon block cartridge filter, both in Camco filter housings and mounted into a milk crate, to do additional filtering/finishing. The milk crate also is used to store all the hoses, fittings and pressure regulator when traveling. Quick connect fittings on everything to make setup and tear down very fast. The system does create a bit of a pressure drop/flow restriction, but the flow at the faucets is still good. And with the filter ratings of the 3 sequential filtration stages it pretty much removes everything as far as sediment and common chemicals. Edited April 3, 2021 by FrankC 1 1 Link to comment Share on other sites More sharing options...
