Fritz Posted February 20, 2021 Share Posted February 20, 2021 On 2/19/2021 at 8:28 AM (under the thread "Length of Sewer Pipe Extension Needed," John E Davies suggested (in regard to dust at the back of a trailer) that "Vortex generators would help a lot, but only if you never slowed below 30 mph😬." Have any of you installed Airtabs on your trailer and/or TV? If so, what was your experience? Less dust? Noticably better fuel mileage? Other? 2021 Oliver LE2 Ram 2500 diesel Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted February 20, 2021 Moderators Share Posted February 20, 2021 Fritz - You might want to take a look at THIS YouTube post. There are a number of additional reviews besides this one on YouTube. Bill p.s. I do not recall anyone posting here on the Oliver Forum about these things. 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
John E Davies Posted February 21, 2021 Share Posted February 21, 2021 (edited) Airtabs work best on a vehicle with a square butt - like 99% of the commercial trucks, travel trailers and motorhomes out there. But an Ollie is already well streamlined in back. It will accumulate dust there, for sure, at any speed. Tabs on the sides and top would most likely be a little helpful at speeds high enough for them to operate. But as I quipped earlier, you have to not slow down below the speed at which they can function. And there is no practical way to install them on the belly, unless you made a big pan there, behind the axles to provide a flat place for them to mount a foot in front of the rear bumper. http://www.airtab.com/how-do-they-work.htm They are easy to install and reportedly not too bad to remove, so you could be the first Ollie owner to try them, and post your before and after dirt road pictures here....;) If somebody were to give me a box of them I definitely would try them. But I won't spend a bunch of cash on what will most likely be a total bust. FYI these are used on aircraft with incredible results, but they are designed to keep the airflow attached to the wing surfaces at unusually high angles of attack (landing, takeoff, low speed). ... https://www.boldmethod.com/learn-to-fly/aerodynamics/vortex-generators/ John Davies Spokane WA Edited February 21, 2021 by John E Davies 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
