Seal the rear Oliver Light (re-caulk?)
I thought it was a head-light light, not a break-light light.  Mine only lights up when my truck head lights are ON, not auto, for example in my case.
Would be nice to have it turn on with the outside courtesy lights too.
Chris
2016 Legacy Elite II  o--o  Hull #110 o--o  Wayfinder  o--o  Twin Bed  o--o  2020 RAM 1500 Limited 5.7L
Augusta, Georgia
Sometimes during Open House at Rallies, I place a low amp blade fuse, 5A between the running light pin and 12V power pin on the trailer's  7 pin connector. This will illuminate Ollie's running lights. Stole that idea from another trailer owner. See trailer plug alignment tang over the fuse placed in top two pins.
Used this larger fuse only as an example, use 5A:
2015 LE2
Don't the courtesy lights turn on with headlights?
I have no idea. We don't have courtesy lights, other than the low yellow sidelights, on 2008 model.
I looked at my Oliver Sign and sternly told it "you will not leak". So far it has obeyed.
Good job all on the posts.
RB
