bhncb Posted May 24, 2022 Share Posted May 24, 2022 45 minutes ago, Jim_Oker said: What do you use to do the test, and what do you use to do the softening? thx An internet search will return a number of sources for "water hardness test strips". I use the On the Go standard portable softener (portablewatersoftener.com) and usually just buy the test strips from them. Cost is a bit more but easy to just add them on to make a larger accessory order. They also have a stainless hanger bracket for the softener that I rigged to hang off the rear bumper behind the water inlets. 1 1 Link to comment Share on other sites More sharing options...
