DonnaDuane Posted September 18, 2021 Share Posted September 18, 2021 Who can tell me the route of the wiring for the factory installed Voyager camera on a 2018 Oliver Elite I? The wire to the Voyager is not the traditional two wire (red/black), so I need to replace it. 1 2018 Elite TV - Audi Q5 3.0 TDI Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted September 18, 2021 Moderator+ Share Posted September 18, 2021 Oliver has traditionally used yellow as their ground wires and purple as the positives. The wiring of the Voyager camera comes through the body into the upper rear cabinet. The white "bubble" insulation covers the wiring, just pull it down to access, it goes back up with a light application of spray adhesive. Grounding for the camera is likely done in the attic whereas the positive wire will run forward to the switch that controls power to the camera. Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
DonnaDuane Posted September 18, 2021 Author Share Posted September 18, 2021 Any idea where the plug is that converts the camera wire to a red black positive/negative wire? Also, what kind of adhesive is used to glue insulation back up? 2018 Elite TV - Audi Q5 3.0 TDI Link to comment Share on other sites More sharing options...
DonnaDuane Posted September 18, 2021 Author Share Posted September 18, 2021 Here’s what I’m looking for 2018 Elite TV - Audi Q5 3.0 TDI Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted September 18, 2021 Moderators Share Posted September 18, 2021 34 minutes ago, DonnaDuane said: Also, what kind of adhesive is used to glue insulation back up? I've used THIS Stuff. A bit expensive but it works. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
Moderators mossemi Posted September 18, 2021 Moderators Share Posted September 18, 2021 This picture is from a 2017 LE2 and it’s the inside of the attic with the installation pulled down. The cable from the camera to the connector is less than 18" from the roof penetration. Mossey 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
BlueHighways Posted September 19, 2021 Share Posted September 19, 2021 I recently dove into this thinking I had a problem with the wiring to the camera. To find the junction you are looking for, I had to remove the hard divider by unscrewing the 2 lag screws. My insulation pulled down easy and went back in place just as easy. As it turned out for me, my antenna had fallen off and I had no real problem. But, the dogwood beside my parking space did! It’s much stubbier now. 1 3 1 David and Vicky | Burns, TN | 2020 LEII #686 | 2017 Ford F-250 4x4 6.2L Link to comment Share on other sites More sharing options...
DonnaDuane Posted September 20, 2021 Author Share Posted September 20, 2021 Yippee!!! New camera installed and working perfectly. Thank you for all your help. Could not have done it without you. 1 2018 Elite TV - Audi Q5 3.0 TDI Link to comment Share on other sites More sharing options...
