Removal of convection oven 2019 LEII
Calypso
36 minutes ago, Calypso said:
Anyone know how to remove the convection oven?
Try a call to the Service department.
While not the convection oven - some models with older microwaves (like mine) are held in via a bracket that actually screws/bolts to the top of the cabinet.  It helps a bunch to see a drawing of how that bracket is attached in order to know how to get to the sheet metal screws that hold the bracket onto the microwave.
Good luck.
Good luck.
Yes. Ours was similarly installed with brackets and a couple pieces of threaded rod. We pulled the fridge when we removed ours. Others have said you can get to the brackets without doing so, but it's really tight.
