GraniteStaters Posted November 9, 2021 Share Posted November 9, 2021 We have had some odd issues pop up from time to time on our Jensen radio/DVD like loss of sound or settings issues. We usually just do a menu reset, I recently had to trip the 60 amp breaker to do a reset on the Jensen. It wouldn’t stay powered on long enough me to get into settings and change the time. I tried several times and it kept powering itself off. Finally I resorted to tripping the breaker. I could have used a fuse or possibly a circuit breaker on the converter, but opted for the main breaker cutoff instead. It resolved the issue immediately after I reset the breaker. David 1 2 David Caswell and Paula Saltmarsh Hull 509 "The Swallow" Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted November 9, 2021 Moderators Share Posted November 9, 2021 Glad you got it fixed. I too have had "issues" with my audio system from time to time - once every two years or so. I suspect that the "computer" chip(s) that run the thing gets "confused" and finds itself in a loop. In any case, a system reset - paperclip into the small hole on the front that is marked "reset" normally does the trick. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
