GRP Posted March 21, 2022 Share Posted March 21, 2022 We just pulled our #1049 home from birth to Shenandoah, Tx this weekend. I want to make sure do not do anything to harm her so I want advice from the educated to supplement the owner manual. The Ollie will be in sitting for a few months. Thanks in advance, Glen & Rhonda Patterson 3 LE II Hull #1049 2022 Tundra Limited 4X4 Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted March 21, 2022 Moderators Share Posted March 21, 2022 If it was me I would just park it. Let the solar charge the batteries each day. There will be some discharge overnight. When I asked my Battle Born rep he said open storing would be fine. They just don’t like the charger to be on all the time. Since you won’t be hooked up to shore power that isn’t even possible. Hopefully we’re done with freezes, especially around Houston. Hope your return trip went well! Mike 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
GRP Posted March 21, 2022 Author Share Posted March 21, 2022 Thanks so much. LE II Hull #1049 2022 Tundra Limited 4X4 Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted March 21, 2022 Moderators Share Posted March 21, 2022 I'd echo what Mike says. However, make absolutely sure that each time you go by her you say hello. New Ollies are particularly sensitive to those that don't "care"!😊 Bill 3 1 1 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
Fritz Posted March 21, 2022 Share Posted March 21, 2022 I'd refer to you to the storage instructions for Lithionics batteries (see below) in Oliver's knowledge base. Your storage approach depends on the length of time in storage and temperature. 3 2 2021 Oliver LE2 Ram 2500 diesel Link to comment Share on other sites More sharing options...
ScottyGS Posted March 21, 2022 Share Posted March 21, 2022 Will the trailer be at your home? Easy to monitor? Assuming you have the Platinum Package (630 ah) ... I would reduce the charge to 13.2 volts per the manual and then turn the batteries off using the BMS power button. Get one of those weather stations with a remote temperature sensor to monitor the temp inside the battery box. If it looks like it's going to get above 86 degrees you may want to take them out and put them inside where the temps will stay in that 14 - 86 degree range. Good Luck and please let us know how things are working out. Scotty PS.. just realized you have the PRO package... I checked the Lithionics manual for those batteries and the storage requirements are the same as for the larger batteries. I would also download the manual and read it thoroughly. 3 Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - Hull # 145 Western NC Link to comment Share on other sites More sharing options...
