John E Davies Posted April 3, 2022 Share Posted April 3, 2022 This pump has worked flawlessly for five seasons, it was good just a month ago when I serviced the water system. Now suddenly it won't make any pressure, it just sort of stutters and lurches.Could this be a pressure sensor failure? Video - SHURflo 4008-101-A65 water pump hiccups I am ready to order a new one - $59 Prime, I guess I got my use out of it. Thanks for any comments. https://www.amazon.com/SHURflo-Revolution-Water-Pump-4008-101-A65/dp/B010TKMK4O This is a really weird week for me, I am losing water pumps. The hot water recirculation pump in my house started chirping like a lost baby bird two days ago, and I ordered a new pump for that system..... John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
1Lessworker Posted April 3, 2022 Share Posted April 3, 2022 Hello John, You could bypass the pressure sensor to rule that out, but having a extra pump on hand is always a good idea, even if you find out the pressure sw. is the problem. Good luck, and let us know the outcome. Harold 2 Sue & Harold Oliver Elite II Twin bed, Hull #508, Ram 2500 Link to comment Share on other sites More sharing options...
VBistro Posted April 3, 2022 Share Posted April 3, 2022 Water pump failures seem to be a thing this weekend…. 1 MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package Link to comment Share on other sites More sharing options...
GarryandKristi Posted April 3, 2022 Share Posted April 3, 2022 Other thoughts ..... cavitation - is the suction side fully primed? Maybe could tell by water in the filter bowl. Have you tried connecting city water and running it for a short period? Although the pump should be self -priming I think. Could be a bad diaphragm. Although the sound on the video sure sounds like an electrical (switch) issue. When ours primes it sounds a bit like a rumble. Garry and Kristi Apex, NC 2018 Oliver Elite II Hull 372 TV 2015 Ram 1500 3.0 L EcoDiesel Link to comment Share on other sites More sharing options...
John E Davies Posted April 3, 2022 Author Share Posted April 3, 2022 22 minutes ago, GarryandKristi said: Other thoughts ..... cavitation - is the suction side fully primed? Maybe could tell by water in the filter bowl. Have you tried connecting city water and running it for a short period? Although the pump should be self -priming I think. Could be a bad diaphragm. Although the sound on the video sure sounds like an electrical (switch) issue. When ours primes it sounds a bit like a rumble. It is not cavitation, the system is full of water and all the air is bled out. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Geronimo John Posted April 5, 2022 Share Posted April 5, 2022 I'm thinking the sound is that of a electrical contact. Maybe just a loose connection. Is the pressure switch a simple in line type on the pump? TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DYI’s: BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DYI’s: 2 5/16" Anderson System, Timken Bearings, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all. Link to comment Share on other sites More sharing options...
John E Davies Posted April 13, 2022 Author Share Posted April 13, 2022 I installed a new one, I will open up the old one some time to see what was going on. John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
John E Davies Posted April 25, 2022 Author Share Posted April 25, 2022 I got tired of the old pump cluttering up my bench. I am not sure why the unit was stuttering, the motor shaft did seem to have some rough spots on it when I rotated it by hand, but it sure looked nice inside and the bearings were smooth. I was surprised to see how clean the pump section was, I do periodically flush with vinegar and my residential water is chlorinated city water. I tested the pressure switch with an ohm meter and it was fine, so I bagged that to keep as a spare, I put all that nice stainless hardware into their proper storage bins 😀 and tossed the rest of the parts. There is a lot of copper on that armature, I suppose I could have cut and removed it to recycle. I was actually impressed with the build quality for a cheap RV part, it seems to be well engineered.. John Davies Spokane WA 1 4 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
