Bill Reed Posted May 8, 2022 Share Posted May 8, 2022 I'm on a long trip and my Zamp Solar Controller has started flashing an error code b01. The leftmost led below the error code displays a solid red, and the rightmost led is blinking red. The manual says this error code means the battery is disconnected or less than 3.0V. The manual also says this combination of leds means that solar power present - no battery connected. Can anyone tell me what is likely causing these errors? I have got about a month of traveling ahead of me and I sure would like to figure out what's wrong. I'm OK right now because I'm staying in campgrounds with AC power, but I have plans to do some boon docking and will need to depend on my solar panels. I'd be very grateful for any advice. Link to comment Share on other sites More sharing options...
geO Posted May 8, 2022 Share Posted May 8, 2022 I've had this happen to me and had to go through a reset. The folks at Zamp are very good in troubleshooting as I don't remember how they helped get it working. 2 Link to comment Share on other sites More sharing options...
bhncb Posted May 8, 2022 Share Posted May 8, 2022 If yours is a later model with a 40 amp switchable circuit breaker under the streetside bunk access, reset this first and recheck for the error. Beyond this, the next step in troubleshooting would be to trace the wiring looking for a faulty connection at a wire terminal. These can occur at the battery, circuit breaker, or rear of the controller. 3 Link to comment Share on other sites More sharing options...
Moderators mossemi Posted May 8, 2022 Moderators Share Posted May 8, 2022 Do you have the ability to check the battery voltage at the battery? If not, you can check the battery voltage on the SeeLeveL tank display by pressing the BATT button. Mossey 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
Bill Reed Posted June 23, 2022 Author Share Posted June 23, 2022 On 5/7/2022 at 11:46 PM, bhncb said: If yours is a later model with a 40 amp switchable circuit breaker under the streetside bunk access, reset this first and recheck for the error. Beyond this, the next step in troubleshooting would be to trace the wiring looking for a faulty connection at a wire terminal. These can occur at the battery, circuit breaker, or rear of the controller. This turned out to be the problem. I had a blown 40 amp fuse, and I replaced it with a circuit breaker that I ordered from Amazon. Fixed the problem and everything is working fine now. Kudos to Mike at the Oliver service department for correctly diagnosing this problem and suggesting I replace the fuse. 2 3 Link to comment Share on other sites More sharing options...
Moderators mossemi Posted June 24, 2022 Moderators Share Posted June 24, 2022 7 hours ago, Bill Reed said: This turned out to be the problem. I had a blown 40 amp fuse, and I replaced it with a circuit breaker that I ordered from Amazon. Fixed the problem and everything is working fine now. Kudos to Mike at the Oliver service department for correctly diagnosing this problem and suggesting I replace the fuse. Thank you for closing the loop on your issue. That information will help someone in the future! Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
roguebooks Posted August 29, 2022 Share Posted August 29, 2022 On 6/23/2022 at 1:10 PM, Bill Reed said: This turned out to be the problem. I had a blown 40 amp fuse, and I replaced it with a circuit breaker that I ordered from Amazon. Fixed the problem and everything is working fine now. Kudos to Mike at the Oliver service department for correctly diagnosing this problem and suggesting I replace the fuse. Where exactly is that fuse? Under the dinette? I remember seeing three 40 amp fuses near the top of the breaker panel. I have a 2018 Elite 1. roguebooks 2020 Ram Classic 1500 Warlock 4x4 Hemi V-8 2018 Legacy Elite, Hull #309 Link to comment Share on other sites More sharing options...
Bill Reed Posted August 30, 2022 Author Share Posted August 30, 2022 The fuse is not under the dinette. It is kind of hard to find. I have an Elite II so my location may be different. In my trailer it is located under the street side bed up toward the front of the camper near the pantry. Here's what it looked like on my trailer before I replaced it. 1 Link to comment Share on other sites More sharing options...
roguebooks Posted January 2 Share Posted January 2 Where exactly can I purchase this 40 amp fuse and what exactly is it called? Can someone provide a link? Thanks. roguebooks 2020 Ram Classic 1500 Warlock 4x4 Hemi V-8 2018 Legacy Elite, Hull #309 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted January 2 Moderators Share Posted January 2 Bumping, as likely someone else can help you. I don't have your equipment. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Moderators mossemi Posted January 21 Moderators Share Posted January 21 On 1/2/2024 at 9:03 AM, roguebooks said: Where exactly can I purchase this 40 amp fuse and what exactly is it called? Can someone provide a link? Thanks. Amazon of course! Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house” Link to comment Share on other sites More sharing options...
roguebooks Posted January 21 Share Posted January 21 Thanks 1 roguebooks 2020 Ram Classic 1500 Warlock 4x4 Hemi V-8 2018 Legacy Elite, Hull #309 Link to comment Share on other sites More sharing options...
