csevel Posted May 10, 2022 Share Posted May 10, 2022 In another thread I posted that I discovered three or four cracked lug nuts on the Sendel aluminum wheels I have on my '17 Oliver. The new set of bulge acorn lug nuts came today and I just want to make sure that they look ok/correct. They seat farther down into the hole than the originals and the threads are not as deep.(about a quarter inch difference) I have zero trouble sending them back, safety first! https://amzn.to/3FzxMFB If you look close you can see the crack in the overlay. The plan is to change them all out, torque to 90# and then again after 50 miles or so. Thanks for any input! 3 2020 Toyota Tundra TRD Sport 5.7L V8 2017 Oliver Legacy Elite II Hull #184 ~ "ILOVHER" Link to comment Share on other sites More sharing options...
Navair Posted May 15, 2022 Share Posted May 15, 2022 You should be good as long as the thread grip length doesn't bottom out, i.e. too short a nut depth engaging the lug. My LE's lugs don't extend very far out of the wheel (can't recall the exact measurement). Make sure the nuts are long enough to get a good grip with the socket you use for torquing too! One of the stock nut's covers stripped out on me during the maiden flight from the"Oliver Birthing Facility." Just the doing a routine torque check. See attached photo with my replacement. 6 Link to comment Share on other sites More sharing options...
Frank C Posted May 15, 2022 Share Posted May 15, 2022 I had some split/cracked 2 piece clad lug nuts as well. I just replaced all of my lug nuts with solid one piece Gorilla lug nuts from Summit Racing. I don’t think the new ones actually seat any deeper into the rim. The conical seating area of the lug nut and rim are the standard 60 degree taper. It just looks like it seats deeper because the new lug nuts don’t have the stainless steel clad cover that protrudes right at the rim. And the female thread depth on the new lug nut is more than enough to fully engage all of the male threads on the lug. https://www.summitracing.com/parts/gor-41187htb 1 6 Link to comment Share on other sites More sharing options...
csevel Posted May 15, 2022 Author Share Posted May 15, 2022 Thanks guys! I'm 5 hours into my trip and lug nuts are staying tight at 90# Checked at 50 miles and 100. 6 2020 Toyota Tundra TRD Sport 5.7L V8 2017 Oliver Legacy Elite II Hull #184 ~ "ILOVHER" Link to comment Share on other sites More sharing options...
Wayfinder Posted May 27, 2023 Share Posted May 27, 2023 @csevel Hope you're doing well. I'm not sure if you made it to the Guntersville rally or not. I was there, but way too many new names to keep track of. I replaced my lug nuts tonight and also discovered SIX cracked lug nut shields on the Oliver-provided lug nuts from 2016, only five pictured. I found this info out at the rally. I should have seen your posting first though. LOL 3 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
Patriot Posted May 27, 2023 Share Posted May 27, 2023 18 minutes ago, Wayfinder said: @csevel Hope you're doing well. I'm not sure if you made it to the Guntersville rally or not. I was there, but way too many new names to keep track of. I replaced my lug nuts tonight and also discovered SIX cracked lug nut shields on the Oliver-provided lug nuts from 2016, only five pictured. I found this info out at the rally. I should have seen your posting first though. LOL @Wayfinder What do you plan to replace yours with? Patriot🇺🇸 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Link to comment Share on other sites More sharing options...
Wayfinder Posted May 27, 2023 Share Posted May 27, 2023 @PatriotI already replaced most of them. I didn't realized until I started putting them on that I only ordered a 20 piece set, but needed 24 nuts. I'll get more a my local auto store tomorrow. Shop around for some better quality than I got, but here is the size. 24 count 1.38 inch Chrome 1/2-20 Closed End Bulge Acorn Lug Nuts - Cone Seat - 19mm Hex Wheel Lug Nut How about these: https://www.amazon.com/Chrome-Closed-Bulge-Acorn-Wheel/dp/B07SLDRL14 6 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted May 27, 2023 Moderators Share Posted May 27, 2023 When I replaced the ones that were rusting on my Ollie I went with stainless steel like THESE. However, even though there has been no problem with the ones I bought, if I replace them again I would most likely purchase solid stainless steel nuts, Bill 2 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
BBL Posted May 27, 2023 Share Posted May 27, 2023 12 hours ago, Patriot said: What do you plan to replace yours with? I found a good selection at Summit Racing - THESE look really nice and they are $10 for a set of 4 so you would need 6 packs of them to complete your trailer. Brian 1 4 Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted May 27, 2023 Moderator+ Share Posted May 27, 2023 These are the best deal I found and it took me a couple of years to find them. They are solid stainless steel. No outer sheath. Seat is perfect and they look great. $3.67 each. 1 5 1 Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
MAX Burner Posted May 28, 2023 Share Posted May 28, 2023 21 hours ago, Brian and Brandelyne said: I found a good selection at Summit Racing - THESE look really nice and they are $10 for a set of 4 so you would need 6 packs of them to complete your trailer. Brian @Brian and Brandelyne: Good choice, IMO. We took your suggestion and replaced our cracked nuts with these a couple weeks ago - stayed tight after a 1400-mile R/T adventure... These have a very nice finish and seem to clean-up easily. 1 2 Art, Diane, Oscar & Magnus (double-Aaarrf!) 2022 TUNDRA w/Airlift Load Lifter 5000 kit/2017 LE II; Hull #226 "Casablanca", 12VDC Starlink kit, 3x Battle Borns; Victron Cerbo GX, SmartShunt, MPPT Solar Controller, & DC-DC Charger; HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
Popular Post Frank C Posted May 28, 2023 Popular Post Share Posted May 28, 2023 Just a reminder for anyone buying replacement lug nuts. Make sure you buy the “Bulge Acorn” type for aluminum wheels. I’ve seen a few owners referencing “Acorn” type as replacements, but the acorn type are for steel wheels and have a smaller conical seating surface compared to the bulge acorn type. Aluminum wheels are softer metal than steel wheels and the larger bulge acorn type lug nuts provide a greater seating surface to prevent deformation of the aluminum wheel and loosening. 5 10 Link to comment Share on other sites More sharing options...
Wayfinder Posted May 28, 2023 Share Posted May 28, 2023 22 hours ago, ScubaRx said: These are the best deal I found and it took me a couple of years to find them. They are solid stainless steel. No outer sheath. Seat is perfect and they look great. $3.67 each. Pricey but high quality. 1 1 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
Wayfinder Posted May 29, 2023 Share Posted May 29, 2023 11 hours ago, Frank C said: Just a reminder for anyone buying replacement lug nuts. Make sure you buy the “Bulge Acorn” type for aluminum wheels. I’ve seen a few owners referencing “Acorn” type as replacements, but the acorn type are for steel wheels and have a smaller conical seating surface compared to the bulge acorn type. Aluminum wheels are softer metal than steel wheels and the larger bulge acorn type lug nuts provide a greater seating surface to prevent deformation of the aluminum wheel and loosening. Thanks Frank. I did not stress that in my video but I should have. I think I know more about lug nuts than I expected, and much more to learn for sure. Such a simple part, but one which keeps the foundation of a vehicle connected properly. Forum contributors are the best. 2 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
Gliddenwoods Posted May 29, 2023 Share Posted May 29, 2023 Moderator+ ScubaRx Posted yesterday at 12:14 PM These are the best deal I found and it took me a couple of years to find them. They are solid stainless steel. No outer sheath. Seat is perfect and they look great. $3.67 each. ScubaRx, are these lug nuts correct for a 2022 LE II? Or does it not matter which model and/or year? Thanks. 1 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs. Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted May 29, 2023 Moderator+ Share Posted May 29, 2023 13 hours ago, Gliddenwoods said: Moderator+ ScubaRx Posted yesterday at 12:14 PM These are the best deal I found and it took me a couple of years to find them. They are solid stainless steel. No outer sheath. Seat is perfect and they look great. $3.67 each. ScubaRx, are these lug nuts correct for a 2022 LE II? Or does it not matter which model and/or year? Thanks. They should be an exact fit. 1 1 Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
GAP Posted May 29, 2023 Share Posted May 29, 2023 On 5/27/2023 at 1:14 PM, ScubaRx said: These are the best deal I found and it took me a couple of years to find them. They are solid stainless steel. No outer sheath. Seat is perfect and they look great. $3.67 each. ScubaRX, it's hard to tell from the brief description on the order site, are these nuts bulge acorn style? My '22 E2 must have aluminum wheels SOLD: 2021 Elite 2, Twin Bed, Lithium & Solar, 3000W Inverter SOLD: 2022 Ford F150, 3.5L V6 EcoBoost, 4x4 Supercab, Trailer Tow Package Link to comment Share on other sites More sharing options...
Patriot Posted June 10, 2023 Share Posted June 10, 2023 @ScubaRx Thank you for the link. Ordered. https://www.ebay.com/itm/144965685434 Patriot🇺🇸 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Link to comment Share on other sites More sharing options...
Rleog Posted August 3, 2023 Share Posted August 3, 2023 I was about to order a set of these stainless steel lug nuts but noticed, at the bottom of the eBay item description, that they are described as Acorn, not Bulge Acorn. Trailer Wheel Lug Nut Package: Contains 24 Lug Nuts Composition Type: 100% Solid Stainless Steel Shape: Acorn Style Thread Pattern: 1/2-20 Right Hand Nut Length: 1-9/16" Long Socket/Wrench Size: Standard 13/16" Size Bob G Link to comment Share on other sites More sharing options...
Gliddenwoods Posted August 7, 2023 Share Posted August 7, 2023 Tighten new lug nuts to 90 lbs; correct? 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs. Link to comment Share on other sites More sharing options...
MAX Burner Posted August 7, 2023 Share Posted August 7, 2023 On 8/7/2023 at 2:48 AM, Gliddenwoods said: Tighten new lug nuts to 90 lbs; correct? We're using 95lb-ft torque setting on ours...FYI 1 Art, Diane, Oscar & Magnus (double-Aaarrf!) 2022 TUNDRA w/Airlift Load Lifter 5000 kit/2017 LE II; Hull #226 "Casablanca", 12VDC Starlink kit, 3x Battle Borns; Victron Cerbo GX, SmartShunt, MPPT Solar Controller, & DC-DC Charger; HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
Mountainman198 Posted August 31, 2023 Share Posted August 31, 2023 On 5/27/2023 at 11:14 AM, ScubaRx said: These are the best deal I found and it took me a couple of years to find them. They are solid stainless steel. No outer sheath. Seat is perfect and they look great. $3.67 each. I just got around to doing my annual bearing maintenance and switched out all lug nuts to the ones recommended above by ScubaRx. They are super high quality and fit perfect. As a side note, I did not find any cracked sheathing on my old lug nuts. Likely had to do with spending most of the year out West and use of a 6 point socket. Thanks Steve! 4 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW Link to comment Share on other sites More sharing options...
John Welte Posted September 3, 2023 Share Posted September 3, 2023 On 5/29/2023 at 6:18 AM, ScubaRx said: They should be an exact fit. They don't look like the bulge acorn style. I thought that with the aluminum wheels, it's recommended to get the bulge acorn style. John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Link to comment Share on other sites More sharing options...
Wayfinder Posted September 6, 2023 Share Posted September 6, 2023 On 9/3/2023 at 5:17 PM, John Welte said: They don't look like the bulge acorn style. I thought that with the aluminum wheels, it's recommended to get the bulge acorn style. John It is recommended to get the bulge acorn style for the aluminum rims. Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
Wayfinder Posted September 6, 2023 Share Posted September 6, 2023 If I did not stress this before. Ensure you have a reliable torque wrench on your trips, one with a long handle for easy torquing. That way you can always ensure both the trailer and tow vehicle's lug nuts are as tight as you want them. I think in this group it sounds like we range from 90 to 110 ft lbs. Especially important: IF you decide to change out your lug nuts, take one good trip, say 1 hour or more, and check all lug nuts when you stop. I found one nut on the trailer that either came lose or I had missed on final inspection. Inspection of torque should like be done a few times until you KNOW the nuts stay where they should. We can't get too lazy here, but we will eventually. We're busy humans. Safety first! 3 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia Link to comment Share on other sites More sharing options...
