Imelda Posted June 2, 2022 Share Posted June 2, 2022 (edited) Hi all. I had discussed my problem of very low water pressure at my shower faucet even with the faucet head removed on an earlier post. No issues at kitchen, outside faucet or toilet. I decided to share this on a separate post on how I fixed the problem since others might have this problem sometime. I bought the vinegar (see pic) at Home Depot and was planning on pumping it though the fresh water tank (bypassing the water heater) and decalcifying before my next trip. But meanwhile I had the idea of removing the faucet head, turn of water or pump and drain as much of the water out of the shower water line as I could. Then I took a syringe - see pic (no needle) and slowly over 1 hr. injected about 2 cups of the vinegar down the faucet hose (see pic) . Be sure to wear gloves and eye protection as the vinegar will burn. I hung the shower hose to the shower holder so I got max amount of vinegar down the hose. Pics need to be rotated 90 degrees. After 1 hr. I went back and turned on the water pump and water pressure is back to normal. 👍 Edited June 2, 2022 by topgun2 pic rotation 2 6 Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted June 2, 2022 Moderators Share Posted June 2, 2022 Better on those pics? Bill 1 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
Imelda Posted June 2, 2022 Author Share Posted June 2, 2022 Thank you for rotating the pics. Looks better now! 1 Link to comment Share on other sites More sharing options...
bhncb Posted June 2, 2022 Share Posted June 2, 2022 Good job Imelda. Sorry I missed your earlier question about vinegar vs CLR but looks like you figured it out. I've never used CLR because white vinegar is always on hand and it works. It's also a lot cheaper with no worries about damaging seals. 5 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted June 2, 2022 Moderators Share Posted June 2, 2022 Ingenious, @Imelda. Great job. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Trainman Posted June 5, 2022 Share Posted June 5, 2022 I had the same problem with my bath faucet and had to take the hoses loose and blow out the bath faucet and sure enough a small piece of plastic blew out the lime. I guess it had finally worked it's self down the line from construction. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Link to comment Share on other sites More sharing options...
Geronimo John Posted April 13 Share Posted April 13 Trainman: Good idea on blowing out the assembly for plastic shards removal. Also, please update both your signature line and profile to include you hull number. Thanks. Imelda! Good post. Thank you. "Slowly over an hour": What were your thoughts for the slow injection process? I was thinking of just disconnecting the hose and dunk it and the faucet head into a small bucket of vinegar? But then you are using industrial strength vinegar..... All: FYI COSTCO also sells 1.3 gallon jugs of 5% Vinegar. But it's no where as strong as Imelda's 30% cleaning and industrial vinegar. The PH scale is not linear! The acetic acid in the industrial version literally will eat many metals. If using this for decalcification the mixing ratios are drastically different than the 50/50 generally posted for run of the mill COSTCO or other commercial grocery store brands. The 30% stuff will blind immediately and burn as well. No kidding here. Specifically per OSHA: "This material is considered hazardous by the OSHA Hazard Communication Standard (29 CFR 1910.1200). SIGNAL WORD: DANGER GHS HAZARD PICTOGRAMS: Hazard Statements: Causes severe skin burns and eye damage. Precautionary Statements: Do not breathe mists, vapors, spray." GJ On 6/2/2022 at 8:32 AM, Imelda said: Be sure to wear gloves and eye protection as the vinegar will burn. . 1 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted April 13 Moderators Share Posted April 13 5 hours ago, Geronimo John said: Trainman: Good idea on blowing out the assembly for plastic shards removal. Also, please update both your signature line and profile to include you hull number. Thanks. Trainman sold his trailer and hasn’t been active on the forum in a while. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Geronimo John Posted April 14 Share Posted April 14 Yea my bad. Was cleaning out my unread notifications and failed to check the date. Hope he is still lurking around. Handy guy for sure! GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
