Can not use electrical outlets with GFCI; normal?
We have plugged our brand new 2022 (#1242) Oiver II into three different electrical outlets with GFCI at three different campgrounds and each time the campground outlet breaker trips; no 120v. If the outlet is not GFCI all is fine and we have 120v service.
Question. Is this normal? Is it correct that all Olivers can not be used with 120v at any campground with GFCI outlets? Or is this situation unique to our new Oliver II? Many campgrounds have GFCI outlets so this situation would be/is disappointing!
Be advise & thanks.
Best to use your power cord at a campground, supplied by Oliver, and plug into their 30 amp outlet.
