Refrigerator fan
twdavid
Are you guys referring to an internal or external fan?
I was referring to my Oliver OEM external fan.  I have replaced both the fan and the thermostat.  My add-on internal fan runs all of the time.
What refrigerator are you referring to?  And what year is your trailer? I didn’t know there was a OEM external refrigerator fan. Thanks.
John & Chris Dehne Manchester, MD.  2021 Elite II twin Hull# 901
“Fiberbeergrass” 2021 Ram 2500 Cummins 4x4  Life is good!
twdavid’s profile shows that he has a 2017 Elite II.  That means his trailer came with a Dometic 3-way refrigerator.  Oliver installed exhaust fans with a manual on/off switch for some time.  All of us responding also have 2014-2017 Elite II’s with the Dometic and manual fan.  It would be nice if folks put a complete signature block so we could quickly see what year and model they have.  If they don’t you can always go to their profile to find out.  Mike
For those of you whose trailers have a refrigerator fan, where is the fan switch located? My 2021 LE2 doesn't have a fan switch that I have noticed. If Oliver stopped installing a refrigerator fan after the 2017 models, does anyone know why?
My fan switch is located on the main switch panel just inside the door.  I don’t know why they stopped, but I do know they are located differently in some trailers.  You can always add your own as some others have done.
Edited by mossemi
Manual spelling correction 😉
Our 2022 has a Norcold fridge. There is an external fan in the rear fridge compartment that is controlled automatically. It moves a lot of air. No manual switch.
I manual switch is REALLY helpful when in the middle of the night that fan decides to start screaming like some demon - don't ask me how I know this.
The Dometic 3 way did not have a fan originally. At some point it started to come with one pre-installed by the factory, so Oliver no longer added a separate fan and circuit. That is how it is in Hull 218, delivered in April 2017. Unfortunately the Dometic fan is located right in the middle where you cannot access it to clean or replace it when it starts to screech. You can barely see it with a flex borescope…
You can disconnect the fan’s power wire from the circuit board, I ran my fridge that way for years, but I no longer recommend that you do that. If the fridge has never been out for inspection, you should do it now and not later. The Oliver Dometic installation is STUPID ENGINEERING, frustrating for the owner and above all it is a  very serious fire hazard. Fact not opinion. Please read this thread:
https://olivertraveltrailers.com/forums/topic/8865-fridge-fires-if-you-have-an-older-hull-you-really-need-to-pull-out-that-fridge-now/
John,
Thanks for the photos and link.
For the folks that have a 3 way Dometic refrigerator fan located where your fan was located, what if they disconnect power to their existing fan leaving that fan in place and install a new 12V fan & auto switch where located on earlier LE2 campers, with manual switch at the main switch panel at the entrance door?
LE2
Found the fan on my 2021 Norcold. You can’t see it by opening both exterior vents. I needed to use my phone to take a picture from bottom looking up.  It would be a ***** to change if needed. I also installed a piece of rubber between the 3/8 gas line after bending in Down a little it’s was rubbing on the black hot gas line. Don’t need a leak on either system.
That's exactly what I did in an earlier fifth wheel we had. Worked great.
John Dehne:
Thanks for the "heads up," with photo, demonstrating the potential for physical contact between the propane line and the black hot gas line on the Norcold absorption fridge.
I checked the Norcold fridge on our Hull #1291.  Fortunately, ours was installed with more horizontal space between the copper propane line and the black hot gas line.   There is enough clearance that, even when wiggled, the two lines cannot contact each other.
804191527_NorcoldFridgePropaneLineClearance.thumb.jpg.f8ffdbe92afe87d4e6d1bf13591e887d.jpg
I recommend that each owner of a Norcold absorption fridge double-check this clearance issue, and address any conflict like you did, by inserting some kind of pliable insulator between them.
Good catch!
