Gliddenwoods Posted March 11, 2023 Share Posted March 11, 2023 I may have to replace my electric water heater element. I have watch a Youtube on the process and it looks straightforward enough. However any advice and/or cautions from those with experience would be welcomed. Thanks. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs. Link to comment Share on other sites More sharing options...
John E Davies Posted March 11, 2023 Share Posted March 11, 2023 Do you have the special 1 1/2” thinwalled socket? breaker bar or impact gun? There are cheap stamped tools, but IMHO you should buy a quality one that will make the job easy. Turn off the shore power and trip the water heater circuit breaker! Open the relief valve lever so that the water pressure will vent. If you don’t have the other tools you need, go ahead and buy a socket for the anode rod so you can remove it. Use a water heater flush wand hooked to a garden hose to flush out any gunk before reassembly. Use teflon tape on the anode when reassemble it. The heating element should come with a new gasket, it doesn’t need tape but the surfaces must be spotless. John Davies Spokane WA 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Gliddenwoods Posted March 11, 2023 Author Share Posted March 11, 2023 1 hour ago, John E Davies said: socket Thanks John....the flush wand is ordered. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs. Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted March 12, 2023 Moderators Share Posted March 12, 2023 @Gliddenwoods, your water heater is surely under warranty. Have you opened a service ticket? 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Gliddenwoods Posted March 13, 2023 Author Share Posted March 13, 2023 Good point SeaDawg, will do so. I just went into the FIY fix-it mode. Thanks. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs. Link to comment Share on other sites More sharing options...
John E Davies Posted March 13, 2023 Share Posted March 13, 2023 Something this simple is easily handled without doing a warranty claim, which will involve a dealer visit or a mobile RV tech. Plus wasted time and aggravation. https://olivertraveltrailers.com/forums/topic/2036-suburban-hot-water-heater-failed-a-dealer-repair-story-and-lesson/ IMHO you should just fix it yourself and move on. John Davies Spokane WA 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Hokieman Posted March 13, 2023 Share Posted March 13, 2023 On 3/10/2023 at 7:40 PM, Gliddenwoods said: I may have to replace my electric water heater element. I thought had a similar problem,right after I picked up my 2021 LE2 from the factory. I assumed I had checked everything before I got too far away, but I neglected to try the water heater on AC, as I was boondocking my way home. When I got home and checked it, it didn’t work. I watched a YouTube on troubleshooting the Suburban SW6DE. I tested the voltage coming into the 130F thermostat (125V), but no voltage after the thermostat. The DC thermostat was OK. I also tested the AC switch voltage (OK), and the heater element resistance (12ohm), so it was OK. I sent in a ticket to Oliver Service, advised them I could fix it myself, and they promptly sent me a new AC thermostat. It took maybe 15 minutes to troubleshoot, another 15 to repair. 3 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250 Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted March 13, 2023 Moderator+ Share Posted March 13, 2023 On 3/10/2023 at 6:40 PM, Gliddenwoods said: I may have to replace my electric water heater element. I have watch a Youtube on the process and it looks straightforward enough. However any advice and/or cautions from those with experience would be welcomed. Thanks. It simply takes a 1-1/2” socket to remove the element. If your set doesn’t have one that large, I’d get one at Harbor Freight. 1 Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
