dewdev Posted May 30, 2023 Share Posted May 30, 2023 I want to be able to see how much propane I have in my 30 lb tanks (instead of guessing) and am looking at either buying an in-line gauge for each tank line or purchasing the BMPRO LP Tank Smartsense Sensors like OTT installs. For those that have either system, I would like to hear your comments/recommendations for each. Thanks 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio Maine Link to comment Share on other sites More sharing options...
Rivernerd Posted May 30, 2023 Share Posted May 30, 2023 I use the Mopeka tank sensor system. It sends reports to an app downloaded onto my phone. It works well. About $70 from Amazon. https://www.amazon.com/AP-Products-024-1002-Propane-Indicator/dp/B01C5RQKJA/ref=asc_df_B01C5RQKJA/?tag=hyprod-20&linkCode=df0&hvadid=312067194179&hvpos=&hvnetw=g&hvrand=12444925943405525704&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9029558&hvtargid=pla-492064932214&psc=1 5 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package Link to comment Share on other sites More sharing options...
BBL Posted May 31, 2023 Share Posted May 31, 2023 I also use the Mopeaka tank sensors and opted for the remote monitoring panel so we can look at them without always going to the app. We use the wall mounted display more than we do the app now. 3 Link to comment Share on other sites More sharing options...
Ollie-Haus Posted May 31, 2023 Share Posted May 31, 2023 We use the Mopeka sensors as well. Only takes about 15 minutes to install and connect to the app on your phone. I also received and installed the wall mounted gauge and it seems to work just fine. I haven't run my tanks empty yet so I can't comment on the accuracy of the sensors but the reviews on line indicate they are very accurate. 3 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted May 31, 2023 Moderators Share Posted May 31, 2023 We eschew the auto changeover. Switch when one is empty Fill the empty. wWe run a hand over the tanks, to feel the difference in temp. Modern gadgets probably work better. 5 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
AlbertNTerri Posted May 31, 2023 Share Posted May 31, 2023 We had the OTT BMPRO tank sensors, had them replaced multiple times, they were accurate when they worked but the battery clip inside the sending units weren't soldered on well and kept failing resulting in the sensors not working. OTT was wonderful about sending out new replacement units but after 2-3 attempts I finally sent them all back and got a full refund. Now we just let the tank run out and switch over to the full tank as needed (old school way of monitoring). IMO the sensors are a great idea that don't work. We found a 30# tank to last about 2-3 days in the dead of winter using the heat all the time, otherwise a 30# tank will last several weeks if just being used for hot water and cooking. 4 1 Albert & Terri Sterns Paonia, Colorado Elite II Hull #1125 Standard Floorplan / 2017 Ford F250 gas Link to comment Share on other sites More sharing options...
dewdev Posted May 31, 2023 Author Share Posted May 31, 2023 Thanks all for your input. I think I will not buy either and stay with the old school system as Seadawg and AlbertNTerri indicated.. 3 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio Maine Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted May 31, 2023 Moderators Share Posted May 31, 2023 10 hours ago, SeaDawg said: We eschew the auto changeover. Switch when one is empty Fill the empty. wWe run a hand over the tanks, to feel the difference in temp. This works for us too. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted May 31, 2023 Moderators Share Posted May 31, 2023 39 minutes ago, Mike and Carol said: This works for us too. "Old School" isn't necessarily a bad thing - it works for me too. Not too sure about the school part - but - I'm certainly old!😁 1 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
MAX Burner Posted May 31, 2023 Share Posted May 31, 2023 11 hours ago, SeaDawg said: Modern gadgets probably work better. Blue Tooth, brother! Blue Tooth!!! HA! 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA w/Airlift Load Lifter 5000 kit 2017 LE II; Hull #226 "Casablanca", 3x Battle Borns; Victron Cerbo S GX, Other Victron Stuff: SmartShunt, MPPT Solar Controller, DC-DC Charger, 12VDC Starlink kit, and Alcan 5-pack Leaf Springs HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
Rivernerd Posted May 31, 2023 Share Posted May 31, 2023 13 hours ago, SeaDawg said: We eschew the auto changeover. Switch when one is empty I expect this works fine if you only camp in warm weather. We sometimes camp in cold weather, and depend on the propane furnace to keep the trailer warm overnight. I prefer to know before retiring to bed that we have sufficient propane in the current tank to run the furnace all night. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted May 31, 2023 Moderators Share Posted May 31, 2023 20 minutes ago, Rivernerd said: We sometimes camp in cold weather, and depend on the propane furnace to keep the trailer warm overnight. I prefer to know before retiring to bed that we have sufficient propane in the current tank to run the furnace all night. Yes, not using the auto-change over feature does have its negative side(s). That first propane bottle always seems to know when to be empty - when it is raining, when it is 3am, when you are right in the middle of cooking that expensive steak for friends, when its cold, etc.. However, the biggest problem is when you do not remember to get that first tank refilled prior to running out of propane in the second tank.😉 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Link to comment Share on other sites More sharing options...
MAX Burner Posted May 31, 2023 Share Posted May 31, 2023 51 minutes ago, topgun2 said: the biggest problem is when you do not remember to get that first tank refilled prior to running out of propane in the second tank. Guys... don't do the following: ...everyone in the Ollie's asleep, dark-out, freezing cold, blowing rain & wind: MAX wakes up, sez to D, "Hey, baby - I'm thinking Magnus needs to pee - how about switching over the tanks while you're out there, eh?" 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA w/Airlift Load Lifter 5000 kit 2017 LE II; Hull #226 "Casablanca", 3x Battle Borns; Victron Cerbo S GX, Other Victron Stuff: SmartShunt, MPPT Solar Controller, DC-DC Charger, 12VDC Starlink kit, and Alcan 5-pack Leaf Springs HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
2008RN Posted May 31, 2023 Share Posted May 31, 2023 I also do the manual switch over. If I’m really wondering how full the tank is, during my pre camp loading/checks I will weight the tanks with a fish/luggage scale. If it goes out during the night, l have an extra blanket at my feet. 2 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648 Link to comment Share on other sites More sharing options...
