• SETTING A NEW STANDARD IN QUALITY TRAVEL TRAILERS
COMPARE ESCAPE, AIRSTREAM AND OLIVER TRAVEL TRAILERS
Compare Escape, Airstream and Oliver Travel Trailers
Whether you are getting closer to retirement and dreaming about the adventures that await you or you’re one of the lucky ones and can do it while you’re younger, owning a travel trailer and setting sail to some of the beautiful country North America has to offer is a common goal on many of our bucket lists.
Researching and finding the right travel trailer for your adventure can be a challenge in itself. We’ve done a little research of our own to see how our 2017 Oliver Legacy Elite II Travel Trailer compares to similar sized Escape and Airstream travel trailers on the market today. Take a look below and we think you will agree that the Oliver Legacy Elite II offers the best value in its class!
Compare the 2017 Oliver Legacy Elite II vs. 2017 Airstream Sport 22FB, 2017 Airstream 23' Flying Cloud and the 2017 Escape 21'
Click Tabs Below To View Features of each Travel Trailer
– BODY, SPECIFICATIONS AND TANKS –
[orbit_tab_2 color_scheme=”#c74c1c”][orbit_tab_2_content tab_active=”yes” nav_tab_title=”Oliver Legacy Elite II”]
OLIVER LEGACY ELITE II
Body | Four-piece molded fiberglass with Prodex insulation between shells
Available Floor Plans | Two Floor Plans – Standard (King-Size Bed) or Twin Bed Floor Plans
Exterior Length | 23′ 6″
Exterior Height to Highest Component | 9′ 7″
Exterior Width | 7′
Interior Height | 6′ 6″
Interior Width | 6′ 7″
Dry Weight (Base) | 4600 lbs.
GVWR | 7000 lbs.
Fresh Water Tank Capacity | 32.5 Gal.
Grey Tank Capacity | 35.5 Gal.
Black Tank Capacity | 18.5 Gal.
Water Heater | Suburban 2-Way Self Igniting 6 Gal. Water Heater, DSI
[/orbit_tab_2_content][orbit_tab_2_content nav_tab_title=”Airstream Sport 22FB”]
AIRSTREAM SPORT 22FB
Body | Riveted aluminum
Available Floor Plans | One Floor Plan
Exterior Length | 21′ 8″
Exterior Height to Highest Component | 9′ 3″
Exterior Width | 7′ 3.25″
Interior Height | 6′ 3″
Interior Width | 6′ 11.75″
Dry Weight (Base) | 3634 lbs.
GVWR | 4500 lbs.
Fresh Water Tank Capacity | 20 Gal.
Grey Tank Capacity | 24 Gal.
Black Tank Capacity | 18 Gal.
Water Heater | 6 Gallon DSI (LP Only)
[/orbit_tab_2_content][orbit_tab_2_content nav_tab_title=”Airstream 23′ Flying Cloud”]
AIRSTREAM 23′ FLYING CLOUD
Available Floor Plans | Three floor plans – 23FB, 23D & 23D Bunk
Exterior Length | 23′ 9″
Exterior Height to Highest Component | 9′ 9″
Exterior Width | 8′
Interior Height | 6′ 7.5″
Interior Width | 7′ 7″
Dry Weight (Base) | 4806 lbs.
GVWR | 6000 lbs.
Fresh Water Tank Capacity | 39 Gal.
Grey Tank Capacity | 30 Gal.
Black Tank Capacity | 18 Gal. with Black Tank Flush System
Water Heater | 2-Way, 6 Gal DSI
[/orbit_tab_2_content][orbit_tab_2_content nav_tab_title=”Escape 21′”]
ESCAPE 21′
Body | Two-piece molded fiberglass
Exterior Length | 21′ 4″
Exterior Height to Highest Component | 8′ 7″
Exterior Width | 7′ 4″
Interior Height | 6′ 5″
Interior Width | Approximately 6′ 8″
Dry Weight (Base) | 3050 lbs.
GVWR | 4500 lbs.
Fresh Water Tank Capacity | 28 Gal.
Grey Tank Capacity | 28 Gal.
Black Tank Capacity | 22 Gal.
Water Heater | 6 Gal DSI (LP Only) – 2 Way option for $200
[/orbit_tab_2_content][/orbit_tab_2]
–CHASSIS –
Axles | Quad Shocks on tandem 3,500 lb. Dexter leaf spring axles
Brakes | “Nev-R-Adjust” 12″ electric brakes
Front Tongue Jack | Electric Powered
Stabilizer Jacks | Electric Powered
Wheels | 16″Nitrogen filled Michelin LTX M/S2 Tires on Aluminum Rims with Black “Rock Guard” Wheel Well Lining
Spare Tire | 15″ spare with aluminum rim
Hitch connection | 7000 Lb. Cast Iron Bulldog Hitch
Frame | 2” x 5” Box Tube Aluminum Frame
Rear Bumper | Hide-Away Brushed Aluminum Storage Bumper with Black/Grey Water Drain hose
Axles | Single 3500 lb. axle w/rubber torsion suspension
Front Tongue Jack | Manual
Stabilizer Jacks | Manual
Wheels | 15″ Goodyear® ST225/75R15 Tires on Aluminum Rims
Spare Tire | Spare Tire with Steel Rim
Hitch connection | Standard Trailer Hitch
Frame | Steel with aluminum skin underbelly
Rear Bumper | No rear bumper
Axles | Tandem 3000 lb. axles w/rubber torsion suspension
Rear Bumper | Polished Rear Bumper w/Storage
ESCAPE 21′
Brakes | Electric Brakes
Front Tongue Jack | Standard Manual Jack – Power Tongue Jack Option for $295
Stabilizer Jacks | Manual Front & Rear Scissor Stabilizer Jacks
Wheels | 15″ Radial Tires on steel rims with mud flaps – Aluminum Rims Option for $380 ($95 each)
Frame | 3″ box steel
Rear Bumper | Box steel
–EXTERIOR –
Furnace | 19K BTU
Air Conditioner | Standard Dometic Penquin 2 (13,500 BTU) A/C with Heat Strips – Optional upgrade to Heat Pump
Exterior LP Gas Port | Option – Exterior LP Service Ports available for Front and Rear
Outside Wash Station | Standard
Battery Storage | Custom Enclosed Slide-Out Battery Storage (fits up to four batteries)
Deep Cycle Batteries | Includes (2) Group 27 Deep Cycle 12V Batteries (Can hold four 6V batteries). Optional 6V battery upgrades available.
Dual LP Gas Tanks | (2) 20 Lb. LP Tanks – Optional upgrade to 30 lb. tanks
Exterior Lighting | (4) High MountLED Porch Lights (2 on each side), (6) LED Ground Lights (3 on each side), LED Rear Brake and Backup Lights, Custom Rear High Mount LED Oliver Sign
Awning | 14ft. Retractable Fiamma Awning available in 5 colors – Option for additional awning on street side
Windows | (4) Sliding Thermal Pane Windows with Sliding Screens & rear emergency egress window
Steps | Fold Up Aluminum Double Entry Steps with Grip Tape
Furnace | 12K BTU
Air Conditioner | Standard 13,500 BTU A/C with Heat Strips – Heat Pump not available
Exterior LP Gas Port | Exterior LP Service Port w/Quick Connect Hose & Adapter Fitting
Battery Storage | Battery Box on tongue (fits two batteries)
Deep Cycle Batteries | (1) Group 24 Deep Cycle Battery
Dual LP Gas Tanks | (2) 20 Lbs. Tanks
Exterior Lighting | LED
Awning | Dark Grey Patio Awning – curb side
Windows | Thermal Pane Windows
Steps | Single Steel Step
Furnace | 18K BTU
Air Conditioner | Quietstream™ A/C w/ Heat Pump & Electronic Thermostat 13,500 BTU
Deep Cycle Batteries | (2) Deep Cycle Battery Group 24 w/ Converter
Dual LP Gas Tanks | (2) 30 Lbs. Tanks
Awning | Dark Grey Patio Awning – Curb side, Option for street side and rear awnings
ESCAPE 21′
Furnace | 12K BTU Atwood Furnace
Air Conditioner | None Standard – 11K BTU Option for $1100
Exterior LP Gas Port | Exterior Propane Quick Connect with 12′ Propane Hose and Adapter Option for $160
Outside Wash Station | Option for $150
Battery Storage | Storage compartment under interior seat fits one battery – optional upgrade to fit two batteries
Deep Cycle Batteries | (1) Group 27 Deep Cycle Battery
Exterior Lighting | (2) LED Exterior Porch Lights, Rear Upper LED Brake & Signal Lights & LED Marker Lights
Awning | 13’ Dometic Power Awning (8’ Extension)
Windows | Standard non-thermal pane screened windows – Upgrade to thermal windows requires $1100 insulation upgrade
–INTERIOR –
Interior Lighting | (15) 3″Overhead LED Lights & (3) LED Courtesy Floor Lights
Window Shades | Day/Night Window Treatments (Excludes Bathroom)
Detector Alarms | Carbon Monoxide, Smoke & LP
Digital Monitoring Systems | See Level II Monitoring System for Tanks and Battery Voltage
Vent Fan | MaxxFan Deluxe RV Ventilator System with Remote Control
Floor Construction | Gel-coat over fiberglass molded inner shell
Insulation | Thermal Break with Prodex Reflective/Foam Insulation
Interior wall construction | Gel-coat over fiberglass molded inner shell
Countertops | Gel-coat over fiberglass
Flooring | 9 Premium Vinyl Floorings to choose from
Upholstery | 9 Premium Cloth Upholstery options to choose from
Interior Lighting | LED Lights
Window Shades | Brushed Aluminum Mini Blinds, Full Close-Out Drapes at Panoramic & Bedroom Windows
Digital Monitoring Systems | Wall Mounted, Probeless Tank Monitoring System
Vent Fan | Comfort Air Fan
Floor Construction | 5/8” tongue-and-groove plywood flooring
Insulation | fiberglass batt insulation
Interior wall construction | Aluminum skin on aluminum frame
Countertops | Laminated
Flooring | Premium Vinyl Flooring
Upholstery | Ultraleather™ (synthetic)
Interior Lighting | Reading LED Lights, LED Interior Lighting w/ Dimmer
Window Shades | Pull Roller Shades on All Windows except Drapes on Panoramic Window
Vent Fan | (2) Fantastic© Fan w/ Thermostat & Automatic Rain Sensor
ESCAPE 21′
Interior Lighting | Double Dome LED Ceiling Lighting
Window Shades | Pleated Draw-Down Window Shades
Digital Monitoring Systems | Unknown
Vent Fan | MaxxFan
Floor Construction | Plywood flooring
Insulation | Rolled Foam – extra insulation option for $1100
Interior wall construction | Vinyl headliner/wall covering over wood frame
Flooring | Linoleum Flooring
Upholstery | Cloth
–ELECTRIC –
12V USB Charging Outlets | (2) 12V/USB Interior Combo Outlet
Interior 110V/120V Outlets | (5) 110V Outlets on GFI Protected Circuit
Exterior 110/120V Outlets | (1) 110/120V GFCI Outlet
Exterior 12V Outlet | Special Request Option
Battery Converter/Charger | 45 AMP Converter with Battery Charger
Solar Package | Prewired, Option – 320W Solar Panel with Charge Controller
Inverter | Option – 2000W Inverter includes Transfer Switch and all 120V outlets
Power Cord | 30 Amp 25′ Power Cord
12V USB Charging Outlets | (3) 12V USB Charge Stations
Interior 110V/120V Outlets | GFCI Protected Outlets (unknown amount)
Exterior 12V Outlet | Included
Battery Converter/Charger | 55 AMP Converter with Battery Charger
Solar Package | Prewired – Option for 80W Solar Package with Upgraded AGM Battery
Inverter | Option
Inverter | Standard 1000 Watt Inverter
ESCAPE 21′
12V USB Charging Outlets | (1) 12 Volt/USB Interior Outlet
Interior 110V/120V Outlets | (5) 120 Volt Interior Outlets
Exterior 110/120V Outlets | (1) 120 Volt Exterior Outlet
Exterior 12V Outlet | Option for $75
Solar Package | Option – 160W Solar Panel with Charge Controller for $850
Inverter | Option – 1500W Inverter Includes Transfer Switch and all 120V outlets for $850
–ENTERTAINMENT –
TV | 24” Flat Screen LCD TV
DVD, AM/FM/CD Head Unit with Speakers | Furrion AM/FM Radio, Bluetooth, HDMI, DVD, MP3, and CD-R/ RW Playback with (4) Custom Mounted Speakers
Cable/Satelitte TV Hookup | Cable/Satelitte Ready
TV | 22″ LED HD TV
DVD, AM/FM/CD Head Unit with Speakers | JVC AM/FM/DVD/CD W/Bluetooth Ability And Microphone with (2) Speakers
Cable/Satelitte TV Hookup | Cable Hookup is Standard – Satelitte is Optional
TV | (2) 22′ LED HD TVs
DVD, AM/FM/CD Head Unit with Speakers | Blu-Ray™ DVD Player, Clarion AM/FM Radio w/ Bluetooth®, Remote with (4) Custom Mounted 30W Speakers & 100W Subwoofer
Cable/Satelitte TV Hookup | Cable / Satelitte / TV Antenna Hookups are standard – includes Signal Amplifer and TV Jack
ESCAPE 21′
TV | Not Included
DVD, AM/FM/CD Head Unit with Speakers | Option for $375
Cable/Satelitte TV Hookup | Option
–KITCHEN –
Cooktop | 2-Burner Cooktop
Refrigerator | 3-way 4 Cubic ft. Dometic Fridge
Microwave | Contoure Stainless Microwave
Cabinetry | Acrylic Faces with Custom Designed Storage Drawers with Dovetail Joints
Refrigerator | 3-way 4.2 Cubic ft. Fridge
Microwave | Convection Oven Microwave
Cabinetry | Laminated surfaces with wood drawer boxes w/ full extension, self closing ball-bearing drawer glides
Cooktop | 3-Burner Cooktop
Refrigerator | 2-Way, 5 cu. ft. Fridge
Microwave | Stainless Microware
ESCAPE 21′
Refrigerator | 3-way 6 Cubic ft. Dometic Fridge
Microwave | Black Microware Option for $110
Cabinetry | Wood framed with Oak Door Package
–BATH –
Bath Type and Features | Wet bath – Molded Vanity with Waterproof Toiletry Storage and Towel Bar, Chrome Faucet with Pull Out Shower Wand, Overhead Storage Compartment
Toilet | Low profile Dometic 311 toilet with porcelain bowl – Option for Nature’s Head Composting is available
Toilet | China Toilet
Bath Type and Features | Dry bath
ESCAPE 21′
Toilet | Thetford Aqua Magic 5 Toilet
–PRICE –
Starting Price | $49,900
Starting Price | $52,900
Starting Price | $71,600
ESCAPE 21′
Starting Price | $31,800 CAD
(Approx. $24,000 USD)
Some of the information above was collected from Airsteam and Escape’s websites and dealer websites. Additionally some data was collected from phone calls to each manufacturer or their dealers. We do not claim the data to be 100% current or correct. Visit the manufacturer’s website for details on their travel trailers.
WordPress Image Lightbox Plugin
Yes No
