BorninPalatka
    274
    2017
BorninPalatka's Achievements
0
  1. Unfortunately the key to the right does not move the latch. The FOB does work this lock.
  2. Does Electronic Keypad Open manually if the batteries are dead?
  3. Jason is sending a replacement latch which we will have to install. We like the idea of drilling holes in the side of the tray & using removable bolts to secure the battery tray.
  4. The movement of the battery tray during driving broke the bottom ‘stopper section ‘ of the vertical latch. I will tell Jason.
  5. After only a few months the latch broke on the battery tray. I would think replacing the latch with the same one would result in a reoccurrence? Has anyone else experienced this problem ?
  6. Convinced Lou Anne she was The One to climb up on the roof! We can see the 2 small white tubs but only from the side. Removed the cover but have no view of the tubs or drain line. This clearly is out of our wheelhouse. Now that we know it is a more complicated I don’t trust local RV centers to fix the problem without damaging the Oliver. We were trying to avoid the 9 hour drive to Ollie plant. On the positive side Jason has told us that the repair is covered by their warranty.
  7. Convinced Lou Anne she was The One to climb up on the roof! We can see the 2 small whit tubs but only from side. Removed the the cover but have no view of the tubs or drain line. This clearly is out of our wheelhouse. Now that we know it is a more complicated I don’t trust local RV centers to fix the problem without damaging the Oliver. We were trying to avoid the 9 hour drive to Ollie plant. On the positive side Jason had told us that the repair is covered by their warranty.
  8. Thanks everyone. We finally found the A/C drain exactly where you told it was. Jason said there is a water gathering ‘tub’ on each the A/C. These 4 tubs flow thru one drain? Under the center of the A/C ?
  9. Bill is it a green tube near the hot water ? Or is the drain a small angled metal opening near the water connections?
  10. John good idea. I will send Lou Anne up on the roof like you suggested!!!
  11. John okay I will send Lou Anne up to the roof as you suggested!
  12. The a/c water is running from the roof down the sides instead of thru the Oliver drain. Any suggestions for an easy fix?
  13. Aside from the 12 month /12,000 mike change of grease lubricant , is there any other maintenance recommended ?
  14. Where do you put this dehumidifier in the Ollie?
  15. Dampaid and small devices arent get the humidity below 85%. Need a real but small dehumidifier.
