DWR
    Pennsylvania
    1619
    2025
DWR's Achievements
Rookie (2/14)
7
  1. O Ring size: 9/16 x 3/4 x 3/32 seems to work fine....... Just thought I would throw that out there in case any one runs into the same issue......
  2. DWR
    Generator
    Thank you....
  3. Love to hear suggestions for a generator. Any thoughts?
  4. Just to follow up on post. What I found ...... No oring, where screen housing connects to pump. Flexible line attached to screen housing did seem a little loose, snugged it up. One of the "quest fittings (unsure if that is the brand) was loose enough to allow air to draw in ....... After correcting these issues, all works great. Small issues easily remedied..... Thanks for the conversations. All tips used and helpful......
  5. I see there is no teflon tape where the screen attaches to pump. Made me raise an eyebrow. That connection might not be the best without it..... Just thinking out loud..... Thanks again.....
  6. thank you.... will give it a try........
  7. Oliver haul #1619, 2025.Legacy Elite 2. Thank you.... I will did follow the de winterization procedure. Thinking going back to a known starting point would be prudent. I will continue and let every one know how it works out.... Again thank you so much for your responses. I absolutely love this travel trailer. But I do have a learning curve to work through. Worked all day, and am "home" for the night. I did have a concern about the trauma water heater with so much air in the lines...... Did not want to harm that in any way. Any thoughts on that? Again thank you all .......
  8. I have gone through all faucets and opened them and closed them. I can hear changes in the sound of the pump. Always keeping under the 2 minute recommendation for pump run time. Does not improve. Still stumped...... I have cycled through 4 minutes of cracking open faucets. Seems like a lot of air in lines. Perhaps I am leaving the faucets open to long. More than a few seconds....... Pump runs very quiet compared to when all is working properly........
  9. I have gone through all faucets and opened them and closed them. I can hear changes in the sound of the pump. Always keeping under the 2 minute recommendation for pump run time. Does not improve. Still stumped...... I have cycled through 4 minutes of cracking open faucets. Seems like a lot of air in lines. Perhaps I am leaving the faucets open to long. More than a few seconds....... Pump runs very quiet compared to when all is working properly........
  10. Fresh water tank full. All lines full of water. Unhooked City water connection. Valves in normal mode. Turn pump on. Opened all faucets one at a time. Pump works fine. Shut off faucet, pressure builds and pump shuts off. Travel to boondocking site., and the pump runs and doesn't build pressure and shut off. Not sure why. Checked connections. No leaks. Any thoughts?
