Director of Operations Jason Essary Posted April 10, 2018 Director of Operations Posted April 10, 2018 The manufacturer of the on-board jacks does NOT recommend using the jacks to lift the weight of the trailer even as a temporary use for changing a tire. New model trailers have an extended steel sub-frame assembly that provides ample room for a jack point either in front or behind the tire that needs to be changed. Older models may not have enough room on the steel sub-frame to use a lifting jack(scissor jack or bottle jack). If this is the case you will simply locate the main frame rail point closest to the tire that needs to be lifted and use a lift pad that will help to distribute the weight. Owner’s manuals may state different things as changes occur every year in the RV industry. There are several reasons why these changes might occur from year to year or even in the middle of a production cycle. Sometimes new industry standards/codes are introduced and changes have to occur to meet these new standards. Sometimes components are discontinued and replaced with a new model that may not work just like the previous model. Sometimes companies simply make a decision change within the company to market their product differently. These are just a few of the reasons that change happens and why your owner’s manuals may be different. Product information is provided by the manufacturer of the component and is available online in the Oliver University section. Oliver strives to provide accurate information to every customer. The product information on components not manufactured by Oliver is dependent on the manufacturer or supplier supplying us with the correct information and as such may not always be 100% accurate. 13 1 ---------------- Jason D. Essary
