If you are having a tough time getting your propane tanks in and out here is a suggestion the works for me. Take a look at the bracket that the gas regulator is on. You will notice that the rod for the bracket that holds the tanks in place runs through both ends of the C shaped bracket. The lower part of the C is what appears to cause the most trouble by getting in the way of the tanks. I removed the braket from the regulator and removed the bottom part of the C with a hack saw. Now I just have an upside down L. Re-installed the bracket and now the tanks are much easier to load and unload.
