MaryandBill
MaryandBill's Achievements
0
  1. Very helpful video! Thanks. I’ll try what he has suggested and see if I can get mine working well.
  2. Thanks. I’ll pursue that with Oliver.
  3. The Maxxair fan stopped working with the manual buttons on the fan, but it did work with the remote. Then it started to make beeps every 10 seconds or so. I checked the fuse and it seemed partially blown, if that’s possible. I put in a new fuse and the same thing happened: beeping, working with remote and not buttons, and the fuse seemed blown again. Any ideas for something to try to troubleshoot this? The fan is 16 months old so still under warranty. Thanks for your thoughts and ideas.
  4. What do you mean by “bump up the A/C”?
  5. That sounds like a likely cause. We are in an RV Park. Everyone is plugged in and running their A/C hard.
  6. We’ve been using the A/C a lot today. It’s the first we have really used it since we purchased our trailer in October. Once in awhile the A/C stops working for a second, the microwave goes off(the lights on the microwave go off as it is not really on)and there is a small pop and both come on again. Any ideas what might be happening?
  7. What do folks do to empty the pee container when parked for a month at an RV Park? Empty it in the bathroom sink? Empty it in the bathroom of the RV Park? Something else?
  8. So many good suggestions! Thank you. I will describe what I’ve done only to still have the drip from the front dinette side scupper hole. This am there was a small puddle, but last night I left the trailer well vented and kept the heat at 58. It got to about 45 degrees last night. This am I opened the dinette covers, all the windows, turned off the water pump and drained the water by turning it on. It was sunny and 60 today. Tonight it still drips:( I’ll call Oliver tomorrow. I’m perplexed and disappointed.
  9. I’m going out to lower the rig right now. Great idea for alternatives to pipe tape. I’ll pick some up and redo that connection. Thanks!
  10. Great help and thanks to everyone for offering ideas. The drip in the rear scupper hole stopped as soon as I unhooked the water from the city inlet. I need to tighten the fitting I replaced last week. Maybe retake it. I had a terrible time getting pipe tape on it in such a small space. The water from the front scupper hole has continued to drip. Would condensation be more likely to occur in the front bathroom corner? There are no other drips except this one.
  11. I don’t see how to check the bathroom sink/shower faucet? Any idea how to take ii apart enough to check the hose connections?
  12. I was mistaken. I did see the scupper hole from inside, but it appeared dry. That’s not possible because it controls drip:(
  13. I stuck my head deep into the well under the dinette seat. I was able to see that the toilet water hose is dry and to see that there is no water at the scupper hole under the toilet water tube. I was unable to see the very front scupper hole where the drip is. Next I’ll look at the bathroom faucet. Thank you!
  14. I have a theory that it is the toilet connection (the outlet behind the toilet) that may be leaking. We have a composting toilet, but that outlet still has water going to it. How would I tighten that outlet?
  15. I just filled the fresh water tank and turned the water off. I will monitor the scupper holes to see if they dry up. If they do, it may be the city water inlet that is still causing the problem. Is there something in the front of the trailer/bathroom that could leak? We have a composting toilet so maybe a loose fitting in the sink? Thanks!
