Mike Griffin
    1428
    2023
Mike Griffin's Achievements
5
  1. Elite II, new 11 Sep 2023. Freedom XC Pro 3000W model 818-3010 Xantrex Inverter, 3 Lithionics Lithium batteries. upon connecting to shoepower on third stop of trip there was no 120v power availble in the trailer. After checking all the normal points we discovered a loose wire connection under the removable inverter cover, A/C out load wire had come loose. This is the Top Orange Compression Connector. Secured wire and restored 120v power. Note: Inverter is off both at the inverter box and the Xantrex remote panel. 8 Oct 2023. Used battery heat due to below freezing temps. Inverter is off. Two hours later xantrex Control App sends Alert msg. E-08, E-21 and E-16 alerts. Utility Power not available/Qualified due to poor quality of AC power. Output overvoltage. No errors on the Xantrex Remote panel. 22 Oct 2023. Used the inverter, turned on at the remote Xantrex panel. Ran Truma air conditioner for one hour. No other loads on the 120v draw. Turned off Truma air and the inverter. Several hours later Xantrex Control App sends Alwrt msg. The app recorded 14 error codes. In coordination with Oliver Service excellent staff (Jason and Mike) plus an input from Xantrex Tech Support a reboot was completed of the inverter. Inverter has reset and is performing as expected with no error codes under numerous utilizations.
  2. 2023 Elite II with Truma A/C, Truma on-demand hot water heater and Furnace, Isotherm frig. Setting uo at campsite once shorepower was connected the Truma Control Panel showed Alert diamond in center at bottom control panel. When selected the code read W255 W. The manuals provided on flashdrive to not list this error code. A/C would not come on when selected. Anyone have full listing of error codes. I think it is associated with power rocker switch behind exterior access panel for on-demand water heater which we were instructed to turn OFF when preparing to leave for next camping location. Mike Griffin
