Tim Casey
    MB Sprinter Van
Tim Casey's Achievements
2
  1. Hello Snackchaser, You were spot on with your advise. It was indeed a polarity issue and I verified that by switching around the pos/neg at the Victron. I have now ordered the 5.5mm to SAE that corrects the polarity issue. Love the Starlink Mini. Thanks again. Tim
  2. Hello Geoff, I loved the install you did and the write up and pictures were very helpful. I tried to install the same converter from Victron , but I am having a little trouble. I did not install an on/off switch and left the jumper in the remote slots. I have a solar panel connector on the outside of the van (SAE type), which I intended to use but was never hooked up . I am using that as the outside connection to power the Starlink. The adapter that I used is an SAE to RJ45 to connect to the Starlink antenna. I adjusted the output voltage to 30 volts at the Victron Orion and measured the voltage to outside connector. The problem is I cannot power up the Starlink( no light) on the antenna, but power light is on the Victron Orion. Works fine when I plug into the 120 in the van. Wondering if you had any suggestions. Tim
