Treasure Coast Vault
    700
Treasure Coast Vault's Achievements
Contributor
Contributor (5/14)
57
  1. I did an overnight in the Ollie last week. Used the Pioneer on Heat. It worked perfectly and the fan cycled on and off with the unit. Great little unit.
  2. I have a step by step on how I did my change out.
  3. I eliminated the control box and used this Thermostat for the Heater. Honeywell TH1100DV1000 Pro-Digital 2-Wire Heat Only
  4. Thanks. Looking forward to the updates.
  5. @Ronbrink I get the same results using the Cielo in my garage with a mini split. Always had humidity spikes in there. Thanks for showing us the Cielo.
  6. Here is a screenshot of the Pioneer sound level in DB in the Ollie. My friends phone showed 38 DB. He has the Penguin 2 on his custom rig (pictured) and he was amazed how quiet and how low the wattage is on the units.
  7. Pioneer has a Remote Thermostat now with an app like the Cielo Breeze Max. No idea if it works as well. https://www.pioneerminisplit.com/products/pioneer-wireless-smart-ac-controller
  8. I like how you rewired. I need to do that. Thank you very much!
  9. I changed the Max Charging Amps to 24 Amps from 50 Amps on the Victron 100/50 MPPT. The #10 wires were getting warm going to the battery. These Panels put out a LOT of power but the good thing is even in very cloudy weather they still stay near 100 watts and with any sunshine get near 300 Watts. They easily out produce the OTT Roof Mount Panels I have which I believe are 340 Watts.
  10. One thing at a time Grasshopper. While u install the axles more videos and products could hit the market. Heck it will be cooling down very soon now you could prolly coast into March and get it then.
  11. If you are going to keep the remote nearby to make adjustments just act like the phone is your remote? The app has a Ton more features. It's very convenient. And you are connected to the AC from anywhere to make adjustments if you have Wi-Fi.
  12. I had the Ollie out in 95 Degree Central Florida Sunshine today and the Pioneer dropped the temperature to 78 and cycled fine. It was drawing around 685 watts. It is also very quiet. I was running off my inverter and the batteries.
  13. Do any of the RV AC Systems have a variable speed fan for pushing the climatized Air? I had a few mini splits in homes and I never saw one that had a variable fan for the climatized air. All were 3 speeds L, M, H and Auto. None shut off after the cycle completed. This is what makes the Cielo Breeze Max T Stat so good it shuts the fan off after the cycle completes if you want that to happen.
  14. I don't think the numbers will change one bit. It cools the Ollie so effortlessly there's not much load in cooling an insulated cooler! ;*))
  15. Have you used it camping? Not Yet Still getting the same numbers? Yes Is it truly quiet or how would you describe it? You can have a conversation with it running For every hour of use on a summer day, how many Ah are used in battery SOC? It only runs a few minutes every 30 minutes or longer. Mine is stored in the Vault in the AC Answers to any of these Qs would be helpful. Also, did you keep the fiberglass platform that OTT had mounted behind the 14x14" A/C opening? Yes I don't believe our hull has that add-on. I'm trying to finalize if this is the right purchase and is now the right time to buy the Turbro Greenland which is now at $1,275 plus tax. Except in warranty and perhaps temp range, the Pioneer and Greenland appear to be the same. minutes or so. Only you can make that call Sorry I can't give you more info.
