Search the Community
Showing results for tags 'ac power'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • News & Announcements
    • General Announcements
  • Oliver Forums
    • Getting Started
    • Introduce Yourself
  • Oliver Campers
    • Oliversary Stories
    • Delivery Day Photos
    • Mechanical & Technical Tips
    • Ollie Modifications
    • Towing an Oliver
    • Service Talk
  • Oliver Camping
    • Campgrounds & Parks
    • Events & Rallies
    • Ollie Boondocking
    • Submit Your Story
  • Oliver Campfire
    • General Discussion
    • Oliver Blogs
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
About Me
Website
Found 1 result
  1. Hey, folks. Just a quick tip about a situation I ran into this week. Symptoms were: - no working AC power outlets and oven down when disconnected from shore power despite the inverter LED being green when enabled - working AC power when connected to shore power - no error codes on the inverter LED in the attic (status "E 0") I checked the GFCI in the dinette area, toggled all of the breakers in the fuse box under the dinette, and checked the fuses + fuse block with multimeter, and then called Oliver Service. Solution: It turns out the inverter (street side, under the bed, and mounted against the wall of the walkway) has a built-in GFCI which had tripped. Simple matter of resetting it. I read through the manuals and never noticed any mention of this GFCI but its possible I overlooked it in my haste. Big thanks to Jason @ Oliver Service for his help!
