Search the Community
Showing results for tags 'extra solar'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • News & Announcements
    • General Announcements
  • Oliver Forums
    • Getting Started
    • Introduce Yourself
  • Oliver Campers
    • Oliversary Stories
    • Delivery Day Photos
    • Mechanical & Technical Tips
    • Ollie Modifications
    • Towing an Oliver
    • Service Talk
  • Oliver Camping
    • Campgrounds & Parks
    • Events & Rallies
    • Ollie Boondocking
    • Submit Your Story
  • Oliver Campfire
    • General Discussion
    • Oliver Blogs
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
About Me
Website
Found 1 result
  1. Thanks to the new narrow panel size that Zamp designed to fit Airstreams, I think you could make it work. No TV antenna, of course, like the 480W system. The trick would be to straddle the AC and MaxxFan with the narrow panels. There's just enough width between them and should be just enough length to maintain the Penguin II clearance requirements at the back of the unit. Here's how it might work. The three panels at the front are what Oliver will do for a 480W system - all I did was add the two narrow 80W panels to the rear. Worst case, they'd just need to use a low profile plumbing vent to slide the panels forward enough, or slide the AC back a bit, just to maintain the AC clearances. Add a couple Zamp 200W portable panels, and you've got yourself a 1kW mobile power station.
