If you have one of the newer Ford SuperDuty tow vehicles and want an aftermarket camera system as a replacement when you remove your tailgate, be certain you know what camera is in your tailgate prior to ordering.  There are several plug and play cameras that purportedly work, but if you have the 360° camera that connects by a coax, you must get a similar camera.
Additionally, be aware that the entire camera system seems to not work without the tailgate connected.  That is after installing the Ford supplied tailgate removed plugs.  There may be something I’m missing, but similar results have been posted on a Ford Forum.
Hull #364 - The Roadrunner
2023 F350 CCLB SRW 6.7L
