Golfnut Posted June 9 Share Posted June 9 After the rally , when we got home i used the pump a times.. nothing.. fuse was good . I started to check, no 12 v to the pump.. i didnt want to to tear into the vanity sw. or the other one on the monitor panel.. I let it go for a while .. i thought i hope i didnt want to trace wire.. I started with the purple from the fuse box ( that feeds the pump 12v). To my luck i guess there was a terminal block that was lying loose, there is a small relay .. connected .. Success.. It was mounted on the street side under bed.. 😅. Major job diverted.. 3 2022 Elite I # 1179 | 2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans Link to comment Share on other sites More sharing options...
srthomsen Posted June 9 Share Posted June 9 (edited) were you able to or did you take any pics of the terminal block / relay that you found to be the issue? Edited June 9 by srthomsen lelft out the quote Link to comment Share on other sites More sharing options...
srthomsen Posted June 9 Share Posted June 9 5 minutes ago, Golfnut said: After the rally , when we got home i used the pump a times.. nothing.. fuse was good . I started to check, no 12 v to the pump.. i didnt want to to tear into the vanity sw. or the other one on the monitor panel.. I let it go for a while .. i thought i hope i didnt want to trace wire.. I started with the purple from the fuse box ( that feeds the pump 12v). To my luck i guess there was a terminal block that was lying loose, there is a small relay .. connected .. Success.. It was mounted on the street side under bed.. 😅. Major job diverted.. Were you able to or, did you take any pics of the terminal block / relay that you found to be the issue? Link to comment Share on other sites More sharing options...
Golfnut Posted June 9 Author Share Posted June 9 No , pics ( I’m not computer savvy). There were about three or four wires going to this little black relay box.. on the Elite 1 it was mounted by the battery box.. don’t know about LE II 2022 Elite I # 1179 | 2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans Link to comment Share on other sites More sharing options...
srthomsen Posted June 9 Share Posted June 9 An Elite 1 is what I we have also. Been liesurely tracing this problem for a while. I did find one wire very loose at the switch on the back wall & fixed that but no luck there. I've found that I have power to the fuse box but I stopped at that point not wanting to start tracing the wiring in some extremely cramped areas. My aversion to electricity ( I can't see it!) has dampened my enthusiasm. I'll have to find my get up and go and start looking again. Link to comment Share on other sites More sharing options...
