I just received my new Starlink Gen 3. I mostly boondocks and thought it would be a waste of power to convert DC to AC to DC to power the Starlink. I found a device that will convert DC 9-36V 15A to DC 46V 3A through POE. It also has a built in switch to deliver the internet signal to the router of your choice. (XLTTYWL Starlink V3 Poe Injector, 150W 2 in 1 GigE Passive & ESD Protection Starlink 12v Conversion Kit with Starlink DC Step UP Converter DC 9-36V/150W for Starlink Gen 3 Dishy) I am using a mini travel router  (GL.iNet GL-AXT1800 (Slate AX) Pocket-Sized Wi-Fi 6 Gigabit Travel Router, Extender/Repeater for Hotel&Public Network Storage, VPN Client&Server, OpenWrt, Adguard Home, USB 3.0, TF Card Slot) uses a USB C power source DC 5V 3A.  I wired a PlusRoc Waterproof 12V/24V to 5V Converter DC-DC Step Down Module Power Adapter Compatible with Raspberry Pi 4, Cellphone, Car (USB Type-C Connector) to power the router.
I mounted everything on a board and powered it from the DC fuse box under the dinette. I will add a waterproof Ethernet port as shown in many other Starlink threads.
It powered up and so far is working great. Even the Starlink mobile app recognizes the signal from the mini router and allows all the Starlink utilities to be used.
I had a Victron Solar Panel Charge controller for a suitcase panel in the spot where I mounted the board so I just moved that to the board as well.
I love not having to turn on my inverter to run the Starlink dishy.
2019 Elite II Hull 435, 2022 Toyota Tundra
