Yes, it has not been smooth sailing.  I keep blowing the fuse in the 12 volt cigarette connector.  I am on a trip and don’t have my tools.  There is a possibility I may have made a wiring error but I have not had time to get into it.  Before I left for the trip, it was fine so just not sure. Will let you know.
ALARCOFLGAINIAKYMEMIMNMOMTNENYNCNDSCSDTN
  • 4 weeks later...
So I solved my issue and it might help someone else.  I learned that not all cigarette plugs utilize the same amperage.  When I went to find a replacement, I noticed that the typical plug is rated for only six amps.  So, I went to Amazon and found a more robust plug, rated at 15 amps, it has two fuses — one in the plug and the other an in-line fuse.  Now all is well.  Rookie mistake, lesson learned .
