I was in need of a little extra light in the dark when backing up so I installed these stainless transom lights with LED's as backup lights. I had to add the circuit to the seven prong plug since Oliver didn't utilize it. The lights are surfaced mounted so I only had to drill a small hole for the wires.
Was thinking of doing this. My actual plan was to mount some lights up above the window pointing down at the corners and have them double as backup/utility lighting. Perhaps when we finish the Airstream I can get back to Oliver projects!
