beeser
beeser last won the day on November 9 2019
beeser had the most liked content!
beeser's Achievements
8
We attended the RV show in Pomona, CA this weekend and stumbled upon a lone Oliver on display. It was strange that no one from Oliver was around. Sales reps from the nearby Airstream dealer were apparently filling in for the traveling Oliver reps that supposedly needed a break. I think the trailer on display was a lifted Elite. It seemed to be getting a fair amount of attention. The show attendance was considerably less than last year and many of the previous vendors and manufacturers were not there. On a more positive note, show staff were handing out free passes this year, at least that was the case when we were there. Prices for everything seemed to be drastically marked down, even Honda generators. We were quoted a show price of $829 for a EU2000iac.
Congratulations on the new trailer. Happy trails!
Sounds like you're on top of the required waxing. Just don't let it oxidize and you'll be fine. As for repairing the scratches, there are tons of instructional videos on the web for repairing gel coat. I've never attempted it yet but the process looks simple enough.
It's good to see that the factory is responding to this issue. However, I would hope that the ensuing resolution and discussion on the "weight problem" would continue on this forum instead of the private correspondence with the factory that BuffaloBob has suggested. Any worthwhile solution deserves to be aired freely and openly in my opinion. Special thanks to member DougI for his many insightful responses contained in this thread.
... And I'm not so much concerned about the towing limitations (we're rated for 5500) - but rather the capacity of the trailer/axle itself being exceeded. - Cherie It seemed odd to me that your Liberty would have a maximum towing capacity greater than mountainborn's Wrangler Unlimited considering the Liberty's shorter wheelbase. So I did a check on the Jeep website and it shows a maximum towing capacity for the Liberty of 3500 lbs. Is the difference because of the diesel?
We did inquire about the weight before ordering, actually - and were basing our decisions off of weight off of the Legacy Elite estimates given to us. The insulation change was made after we ordered, and we were only the third to receive the new method of insulation. At no time were we told that the base weight was increased so much as a result. And I'm not so much concerned about the towing limitations (we're rated for 5500) - but rather the capacity of the trailer/axle itself being exceeded. - Cherie What was the weight that you were told for the Legacy Elite? I'm confused, I thought Oliver changed the axle to a heavier duty one with a 4500 or 5000 lb. rating. Is that not the case with your build?
Cherie - I didn't say you were stupid and never would suggest it. I realize you meticulously researched the options but perhaps you assumed too much regarding the base dry weight. The current Oliver website shows a dry weight for the Legacy at 2400 lbs. Maybe this was recently changed and the previous published weight wasn't clearly specified as being for the base Legacy. However, with only one weight shown it seems reasonable to me that it would be for the base unit. Perhaps, in hind sight, that was a question to raise with the factory prior to purchase. As for the added insulation weight, manufacturers make design and manufacturing changes all the time. I have never seen a manufacturer held to precise details contained in a sales brochure. Assuming you only have issue with the added weight, why not ask Oliver for assistance in resolving your towing limitations. They may have some ideas. I wish you well in your travels.
The fresh and grey water tanks are both long and flat rectangles that are seated side by side inbetween the hulls and into the frame. They run from front to back, and thus the weight on those tanks is pretty fully distributed. The black water tank sits directly underneath the toilet on the front streetside of the trailer (aside for the apx 6 gallons of pipe that goes to the dump in the rear, which accounts for some fo the capacity.) We too are quite concerned about the CCC given these new measurements. As we fulltime, we *have* to keep everything we own in either the TV or the trailer, and were lead to believe we would have ample capacity to carry what we needed. We weren't even told that the insulation method was being changed until after it was applied and now to find out that it took away 250 lbs of our carry capacity. Well, yes, this is disappointing to us to learn now that we're out on the road and potentially traveling unsafely. I too would like to hear an official response from Oliver on this issue. - Cherie I'll probably receive some flak from this but those of you that have dressed your Olivers with numerous accessories should have realized that added weight would be a consequence. It seems to me that Oliver has gone out their way to increase the load carrying capacity of the trailer by installing a stronger axle and springs without increasing the price. I hope it doesn't turn out to be a favor that comes back to haunt them. Sitting on the sidelines with an Oliver purchase I have to admit seeing some of this coming. While Oliver has been trying very hard to get a product off the ground I'm sure they've been hit with countless suggestions, probably most of them having to to with added features. They have surely been accommodating based on the kudos expressed here on this forum. But all of this "one more itis" comes with a price. I think the direction of this thread should take pause and remember what Oliver has accomplished with respect to molded fiberglass trailer advancement. The end user has a role in that process too.
...I also wonder what the weakest link in the GVWR calculation would be for the Oliver? My guess is it would be the frame, then the tires and wheels. With a 5,000 pound rated axle it would not be that... Don't know for sure but I too suspect the frame is the weakest component primarily because of the aluminum. There was a molded fiberglass travel trailer with an aluminum frame made years ago that was prone to bend and subsequently break at the wishbone immediately in front of the trailer body. However, I don't recall it having a central boxed spine as with the Oliver. The other part that would concern me, especially with the added weight discussed here, is the extended tongue. Modified with added accessories like generators, etc. makes it even more worrisome.
Beeser, tell me more about your Tacoma. I have thought that would be a great option for towing the Oliver. Does it have the factory towing package? Two or four wheel drive? What mileage do you get towing your trailer with the Tacoma? What mileage by itself? Year and miles on the vehicle? Thanks, Doug 2004 Tacoma 2wd Prerunner (V6) automatic with about 38k miles Factory tow package 20-21 mpg highway/16-17 mpg city 13-15 mpg towing regardless of conditions As I said before, the Tacoma tows my 3700# (loaded) Bigfoot OK on the flats. Anywhere else with hills is frustrating.
I found a towing solution. My daughter and I will switch vehicles every time we use the Oliver. She will take my RAV4 (and save on her fuel cost) and we will get her 2008 Silverado LTZ 4WD CC short bed truck with towing package. We will save on fuel cost, compared to using our Duramax big dually and have a very able tow vehicle for the Oliver, with thousands of pounds of extra towing capacity, along with a truck bed to carry other goodies, like our two Honda 2000i generators, with gas can. Problem solved. Doug PS: Now I have to decide if I am going to install the towing equipment I purchased for the RAV4, so I can give that option a try, once I get the Oliver back home, in late October. I think I could use the RAV4 to tow the Oliver on in-state trips, down to the coast for example. I don't tow at speeds over 55 mph, and I think the RAV4 would do fine as long as it stays out of the mountains. I have air bags ordered for it so I can keep it level with the Oliver tongue (fully extended) weight on the hitch. Sounds like a terrific plan. Glad it came together for you. I think you'll be surprised initially how well the Rav4 will tow the Oliver on the flats but you'll also quickly realize its limitations. Coincidently, the Silverado or equivilent Sierra is what I'm currently looking at to replace my Tacoma. Please keep us informed on your impressions using both tow vehicles. That would be a great read especially for newcomers to towing.
The weight of Doug's Elite is about 400 lbs. more than Bigfoot's 17.5, which has considerably more interior space because of the 8 ft. width. The Oliver is no longer a light weight trailer. Doug - Since your trailer is very close to the weight of mine I would suggest taking a hard second look at your intentions to use the Rav4, especially if your travels will include a lot of mountains and steep grades. Our V6 Tacoma (similar engine size to your Rav4) performed well enough on the flats but steep grades were frustrating. Besides, it's very likely that you will be towing in excess of the towing capacity. We had over 1500 lbs. reserve towing capacity with our Tacoma and we're now looking for a stronger tow vehicle. Good luck!
Link to the show schedule on the home page: http://olivertraveltrailers.com/calendar That's one busy schedule for the next couple of months. Heck yes they'll be showing the Oliver. Pam, I think you got a bit carried away with . Now we know the impetus for the recent price increases. It's beginning to remind me of the Cimarron from Cadillac, marketing wise. Sorry but I think it was better with Jim Oliver carrying the torch.
Ok so 33 off the line so far. Typical for my wife to find the newest and most exspensive. How costly are these? she is telling me aprox $30000. and what are the differences between the elite and the classic? does my 1970's Nomad stick and tin Canada style get me a discount? probably not eh! A little canadian for yaall. Is that how you spell that (yaall)? Oliver's website is http://www.olivertraveltrailers.com/. That should answer your questions about the differences between the Elite and Classic models. I believe member mountainborn expressed an interest in selling his to get a newer model. Might be worth a try.
A 6000 lb. rated axle only weighs about 30 lbs. more than a 3500# rated axle of the same design according to a catalog from Croft. They didn't have one rated at 4400 lbs. to draw a more accurate comparison with the one used by Bigfoot but it probably doesn't weigh more than the 6000 lb. rated one. Besides more load carrying capacity the heavier duty axle comes with larger brakes. I thought it was interesting that prior to 2005, Bigfoot used 3500 lb. rated axles on their 17 ft. trailers. They were called 1500 Series at the time. Then, in 2005 when the 17 ft. trailer was redesigned and the length increased (a little less than a foot) they began using a 4400 lb. rated axle. The dry weight of the 1500 Series trailers were about 2600 lbs., not much heavier than the Oliver and their storage tanks were smaller. Just seems to me that a heavier axle on the Oliver is worth looking into.
